Results 1 to 15 of 15
Thread: interior door trims?
    01 magna exec
    Feb 2006
    gemfields qld
    Default interior door trims?
    just wondering do i have to specificly get vb door trim or will just about any fit? the ones i took aout of my car are all ragedy and cut.. ( previous owner had kids )
    R.I.P Peter Brock - 26/2/1945 ~ 8/9/2006 - We'll all miss you
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    make up some new ones of your own. i did it in the vh. went to a hardware store, got a sheet of thin mdf (get the sturdiest yet thinest you can) and used the old trims as a template.
    i still used the old vinyl as it wasn't too dead, but i dont' see why you couldnt' recover it in some new material.
    ECOTEC KICKED IN yO!!!!!!
    01 magna exec
    Feb 2006
    gemfields qld
    yeah i thort about makeing my own same as a few things.. just wasnt to sure how to go about it.. i do now lol.. thanks ^_^
    hsvtj's Avatar
    hsvtj is offline now cruising..
    VK wagon, VS Statesman 5.0
    Jul 2005
    Berwick
    Quote Originally Posted by vh-holden
    Hey have u got any pics or more details on the door trims, i was thinking about doing the same thing??
    thanks mate
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    I have been told that MDF is no good, soaks up all the water/moisture and stuffs them. Also with MDF none of the sealers/varnishes work either which sucks.
    Can use plywood or what the original door trims was made out of, hardboard.
    01 magna exec
    Feb 2006
    gemfields qld
    thinkin bout just useing sheet metal lol.. but ya i dunno..
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    sheet metal now that is different!. well the door trims on the VB-VL are about 3mm thick. But sheet metal i reckon go for it.
    Aug 2005
    Aren't the origanal ones made of masonite? if they are you could just replace them with that, wouldn't be too hard to get hold of some the right size.
    May 2004
    darwin
    masonite is the stuff!!!! all looks the same to me.
    use masonite. it still goes funny when it gets sopping wet, but it shouldn't get sopping wet.
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Masonite is crap. What the trims are made of I think. It's about as good as particle board or chip board. When it gets wet, it destroys it and warps. MDF is good stuff and they should make more shelfs and trims with it. It is stronger and withstands moisture more than masonite and chip board. Sure, MDF soaks up stuff which you notice when priming and painting it but it comes up nice. Ply wood is very good and probably the best apart from a sheet of pine. Ply wood is good if it comes in the right thicknesses but it costs more than any of the above.
    Aug 2005
    If the doors are fairly mint, they should still have the plastic lining between the door trim, and the metal frame of the door, if you give this plastic a new seal, or new plastic alltogether. If you do this and make sure the seal (between the trim and the glass window) is still good, you can then use whatever material you want as it will not get barely any moisture.
    01 magna exec
    Feb 2006
    gemfields qld
    thanks heaps guys big help as usual ^_^
    85 VK Sedan 3.3 Injected
    Feb 2006
    Christchurch
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    i have blue vh seats in my vk so vk trims will fit.
    but only thing it vk and vl? have a funny sliding lock not the push down pin type one.
  15. #15
    VK 3.3i, V6 VL in Production
    Apr 2006
    Bathurst NSW
    Quote Originally Posted by V3N0M
    If you use sheet metal, make sure you use heaps of foam or insertion rubber otherwise it will pop and buzz from vibration. Drive you nuts.
    kain
  1. SA Interior seats & door trims
    By CALAIS 6 in forum Swap / Wanted to Buy / Trade
    Last Post: 28-10-2007, 09:39 PM
  2. VR/S door speaker pods in vn ss door trims?
    By dawg in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2007, 09:42 PM
  3. Door trims
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2006, 08:54 PM
  4. Replies: 2
    Last Post: 29-08-2005, 08:01 PM
  5. Berlina interior door trims...
    By VL Soldier in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-08-2005, 12:38 PM
