Results 1 to 5 of 5
Thread: Varajet Out! Weber In!
    cecil strike Guest
    Default Varajet Out! Weber In!
    i have finally gotten the shits with the varajet II carby and am wanting to put on a weber 34adm (or possibly the 32/36) carby on my basically stock 1980 blue 202 (with extractors). i have very limited mechanical knowledge. i would really like someone in the know to give me a heads up on a few issues i have. i want an adapter to fit the weber to the original intake manifold.
    1. does the adapter plate just bolt on, what adapter do i need (model no.)?
    2. do i need to hone out the manifold at all to allow the weber to flow easily (if so, do i need to take off the inlet manifold to do this)?.
    2. will my fuel pump be sufficient to handle the carby?
    3. how do i change the jets if the carby is from a larger engine (or what is a good carby to get that will suit the blue 3.3 other than xe xf 3.? litre)?
    4. what air filter can i put on top the carby that will fit and be under the bonnet(model no.)?
    5. how do i modify the accelerator cables to fit this new carby (a guide possibly?)
    6. what pipes go where, what can i block off?
    7. how do i know if a used carby is any good or how do i reco one?
    I know this is quite demanding of me but i am hoping that many of you on here have done this exact conversion and are willing to shed some light or point me in the right direction. i am young and broke!
    cheers, cecil
    bacon-n-eggs is offline Tyre Frier
    VL shitbox, in need of a snail!!
    Jan 2006
    EF Almost Turbo
    Jun 2005
    i thought that xe-xf were 4.1L..
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Redline do an adapter plate, bolts onto the manifold and the carb bolts onto it. When I was looking at putting one on my carbie VK I was going to pull the inlet manifold off and drill & tap new mounting holes for the new carbie & plug the old ones.
    It you do decide to do any machining work on the manifold take it off the car. Filings & rings dont mix
    The Ford inline was a 4.1L, there are jet kits available, my engine was modified so i was going to try it with the larger jets, a carbie specialist will be able to jet it correctly for you.
    I was going to use the standard VK air cleaner but cut out & weld in the ford centre so the car looked stock.
    Accellorator cables & piping I didnt go into but should be similar to a holden, have a look at a ford workshop manual to see what they are used for and connect them to the correct places for your engine. eg vac advance for the dizzy, maybe EGR etc...
    really a second hand carbie is an unknown, check for play in linkages & butterflys, pull it appart & check for wear in bushes & sleeves. If you buy one from a wreakers, tell them what your doing, maybe ask to pull it off the car/engine that way you know where everything goes.
    cheers
    Scott
    VZ Executive Wagon 2006 & VR Executive Sedan 1993
    May 2004
    Australia Victoria Geelong
    you can buy carby kits and also buy a can or two of carby cleaner and strip the carby and give it an all over clean as best you can then slowly put her back together. A manual would be helpful as well were they have a diagram of the carby you working on.
    VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
    VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
  1. howto: weber onto vh?
    By farkamhall in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2007, 07:10 PM
  2. Weber Adaptor plates
    Last Post: 18-12-2007, 09:09 PM
  3. weber conversion help please
    Last Post: 17-12-2007, 01:50 PM
  4. Weber Conversion
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-09-2007, 07:46 PM
  5. weber conversion
    By jimrichards1964 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-01-2005, 06:19 AM
