Results 1 to 6 of 6
Thread: V8 Trans cooler lines
    1992 HSV SENATOR 5000i
    Apr 2006
    N/W NSW
    Question V8 Trans cooler lines
    Hey all, hoping you can tell me which is the feed line & which is the return line on a Holden V8 Trimatic? Cheers.
    the lightning
    Jun 2005
    under the Southern Cross
    if theyre still connected the fluid should flow uphill through the radiator so out of the trans and into the bottom fitting in the radiator and out of the top fitting in the radiator side tank and back to the trans, dont know which ones which on the trans itself unfortumately, hope this helps.
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    The line closest to the Bell housing is the pump out line.The line running to the rear of the Trans(near the Vac Mod) is the return.
    Apr 2006
    N/W NSW
    Thanks, what you said is true but I have the problem of having to run all new lines in a project car but can't remember which hose was which cause some di*khead(me) tossed the old ones.
    Can someone run out to their car please & stick your head under & tell me if the front or rear outlet hose on the gearbox goes to the bottom fitting on the radiator
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    here you go the attached diagram should sort you out.
    cheers
    Scott
    Attached Thumbnails Attached Thumbnails V8 Trans cooler lines-trans-cooler-pipes.jpg
    Apr 2006
    N/W NSW
    Quote Originally Posted by 308vkcalais
    Cheers mate, you got in while I was typing my reply
    & thanks for the pic scott, your a champion.
  1. Auto Trans problem when hot - need a trans cooler ??
    By woteva in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2007, 11:41 PM
  2. V8 trans cooler on a V6
    By IhateRICE! in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2007, 08:20 PM
  3. Trans Cooler Group Buy
    By OLS108 in forum General Discussion
    Last Post: 18-07-2006, 10:03 AM
  4. Exterior Trans Cooler
    By VTSSDUDE in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-11-2005, 09:07 AM
  5. VR Trans Cooler
    By Mk III the HSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2005, 10:54 PM
