Results 1 to 6 of 6
Thread: removing front shock absorber - it is stuck
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    Default removing front shock absorber - it is stuck
    I'm having trouble getting the front right shock out of the vh. We've undone all the bolts, but it won't budge. we even put the jack under the shock, and jacked it up so a tonne of car was pulling down on the bolt, but nothing. It is the bit that joins the shock end to the swingarm.
    any suggestions on how to get it out? or should we just unbolt the swing arm and swap the whole lot?
    adam
    ECOTEC KICKED IN yO!!!!!!
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok I think your refering to the ball joint there is a single nut with a split pin though it. You reall need a ball joint separator to remove it esp if its been in there the last 20+ years.
    Unless you want to replace the ball joint, just unbolt the suspension arm and let it drop you will probably need to remove the radius arm & the ball joint for your steering rack.
    cheers
    Scott
    May 2004
    darwin
    i think i might go and take a photo of what is there and put them up. i don't know the names of the bits. we've undone the nut on the ball jointed bit, but it won't budge. the other side came out easy.
    we had the same problem on the VP the replacement shocks are out of. left side came out easy, right side took a lot of work.
    May 2004
    darwin
    the side that won't move
    the side that is all out
    the only thing i can think of is the sway bar being still bolted up on the other side.
    Mar 2004
    That is the ball joint, it is a tapered fit into that hole, so it is a tight fit in there on purpose. Give the casting a whack either side using a long bar and a hammer, this causes the casting to move a bit and hopefully come away form the bolt. You can also spin the nut back on the bolt so that the bolt is just inside and the thread is protected and put a block of wood on it and hit the wood with a hammer.
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    We made a beauty ball joint remover out of an old block splitter.U can buy ball joint removers for around $20 a good investment.You think you buy these things to use them once, I've used mine many times.I took my lower control arms to Pedders to remove & install new ones.I think it was $10.I supplied the ball joints, they just pressed them off & on.
  1. removing front seats
    By Co0kiE MoB$tA in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-03-2010, 05:30 PM
  2. Front rotors stuck
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2007, 06:41 PM
  3. Can anyone tell me the actual size of the lower shock absorber bolt for a VT wagon?
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2006, 11:39 PM
  4. lowering vs...shock absorber recommendations??
    By orchie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2006, 05:05 PM
  5. Removing stuck sump plug.
    By Uber_Matt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-03-2006, 09:14 AM
