Results 1 to 7 of 7
Thread: wont turn off!!!
    16 vk boy Guest
    Default wont turn off!!!
    gday every one yet a nother slight prob
    when i go to turn off ma vk it stays on for a few seconds and then conks out
    ??? ????is this just the engine just doin its last thew turns or wat
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    VK berlina sedan 202
    Jun 2006
    Can you tell if it is Dieseling or if it sounds like it is running properly for a few seconds.
    If it is dieseling, then it can often be your fuse connected to your anti-deiseling solonoid on your carby. This is also often connected to the bimetallic strip in the auto choke.
    It could also be your timing, cooling system etc etc.
    If the engine is actually running normally for a few seconds, then you are probably looking at an ignition problem as stated by the previous poster, as in, the ignition hasn't turned off for some reason.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    At first it sounded like the OP was describing it as dieseling but it sounds more complicated than that.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Could be dirty wiring or accelarator getting stuck.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Jun 2006
    I would be very suprised if it wasn't dieseling.
    Once again, check your timing and your anti dieseling solonoid.
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    It definatly sounds like the anti deiseling solinoid to me.
  1. immobiliser wont turn off, car no go,
    By tonykt47 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2011, 07:49 PM
  2. HELP!! VL wont turn ova!!!!!!!!!
    By DumpdVL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-03-2007, 01:42 AM
  3. VR wont turn over
    By AJKoo1 in forum General Discussion
    Last Post: 20-09-2006, 06:47 PM
  4. fan wont turn off
    By potshots007 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2005, 10:59 AM
  5. Help car wont turn over
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2005, 04:24 PM
