Results 1 to 24 of 24
Thread: vt ss wheels on a vk?
    vk commodore sl
    Mar 2005
    sutherland shire-sydney, NSW
    Default vt ss wheels on a vk?
    ok ive got a workmate whos offered me some 17'' vt ss wheels with good tread, but i have heard on the grapevine that they dont fit up and some sort of modification has to be done to fit on the hub? the vk has disc front and drum rear.
    hope u guys can fill me in on this
    cheers cam
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    Vs clubby daily driver & vb project car
    Jan 2006
    they will fit straight on, i had a mate a few years ago who put vt ss's on his vk calais and he had no dramas.
    Aug 2005
    All commo's have the same stud pattern, so the latest HSV or Monaro rims would fit on a VB, the only problem you may encounter would be if they are 17x8 and you had super-low springs, then you would need the guards rolled.
    But in short, yes they will fit, i can gaurantee it, i have seen about a million early model commodores with VT SS rims
    VS sedan and a VK DRGWGN
    May 2004
    darwin
    the problem is with the big round bit that sticks through the middle of the wheel. there was a slight change in size with the vt. the wheels still bolt on, but are only held on by the nuts, and not supported fully by the hub. whether this is an issue or not....?
    ECOTEC KICKED IN yO!!!!!!
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Thats it vh-holden, the bit that sticks out(i can't remember the name) is the issue. Cause all the strain is ment to on that part. But putting VS-VE rims onto a VB-VR all the strain is on the studs and it can break them.
    May 2004
    darwin
    i thought it was vt onwards. vs wheels are the same as vb-vr
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    I think late VS they changed. Might be series II.
    VE SII Sv6 Manual
    Aug 2004
    Hub centre is the same size on all commodores. 70mm
    the VT's have a stepup to 71.5mm for the disk, but wheel is still 70mm. The only problems that can be encountered are some alloy wheels don't allow for the wheel bearing caps that are on VB to VP commodores. as VR and latter have sealed hubs that don't poke through as far.
    vk commodore sl
    Mar 2005
    hey guys yeah thanks for the comments.. thats what ive heard with the centre dish piece on the vt ss rims.. i guess all i can do is try them on and go from there. i dont want the nuts to take the load of the wheel. the hub has to. i know mates who have aftermarket rims and doesnt have a plastic hub ring with the nuts taken the load. one even cracked his rim.. but another has been all good.
    why on earth did they change the vt hub diameter!! the mind boggles
    cheers, cam
    Aug 2005
    Alot of car companies change the wheels on each model or every couple of models (they have on the falcon), so i guess we should be happy with the freedom in choice of wheels that we have.
    VK 3.3i, V6 VL in Production
    Apr 2006
    Bathurst NSW
    Quote Originally Posted by vk_dog_208
    cheers cam
    Nah thats all BS mate. I have 235 x 45 x 17 on my standard hub VK. they fit with heaps of room. Could prbably go to 19's without too much trouble.
    Kain
    Aug 2005
    Quote Originally Posted by darkmoon
    Kain
    Well that will depend on the ride height, i have super lows with 235x45 17's and they scraped really bad (only the fronts), and the guards needed to be rolled.
    Apr 2006
    Bathurst NSW
  15. #15
    WH Caprice gen 3, 1975 HJ Statesman
    Jul 2006
    Esperance, Western Australia
    Im planning on putting 17s on my VH SLE soon and have friends with them on there vbs and vcs and havent had any problems. One of them put them on to go over the pits a couple of months back in perth before i moved to adelaide. He also had super lows on his commodore without any scrubbing.
  16. #16
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by vh-holden
    No big deal untill the wheel studs let go one day (probably as you go over a railway line or some other big bump) Depending on how many break, things can get a tad exciting
    IIRC VT onwards had a different offset to the earlier cars too. Your insurance company would probably have issues with 17" wheels on a VK.
    Cheers,
    Reaper
  17. #17
    phat_com's Avatar
    phat_com is offline VR IS A BEAST WITH NEW V6
    VR s2 Acclaim/VK IS GONE :(
    Jan 2006
    Tuggers (da hood),ACT
    Quote Originally Posted by Jimboss
    my mate bryce had cut springs (2 coils lol) on his (my) vk and he had vx 17" rims and it only rubbed around corners and bumps in the road
  18. #18
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    I had 235x45x17 on my VKC, fronts scraped like a bitch on sharp corners & bumps front wasnt lowered either. I would say roll your gaurds anyways. Not worth the hassle if they 'might' scrape or not....
    & 17's are legal on the Calais because it came factory with 15's.
    Mate of mine has 19's on his VK..... & with gaurds rolled he still scrapes lol wayyyyyy low that thing is..... hehehehehehe
    D.
  19. #19
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
  20. #20
    1992 HSV SENATOR 5000i
    Apr 2006
    N/W NSW
    Back to the original question, I had VT SS rims on my VK, It had s/low kings, adj panhard rod & it NEVER scraped once. I was going to fit 16" walkinshaw rims but they will only fit with four wheel discs as the rear of the rim is machined to fit over the hub to get the offset right for the VL(genuine rims only, the cheap n nasty copies will fit drums).
  21. #21
    hocus Guest
    i have VT clubsprt rims on my vk, never had a problem, they have been on for about a year now.
  22. #22
    Apr 2006
    Bathurst NSW
    Rego is only an issue in certain states I think. I don't know about other states but in NSW you can oly go 1" bigger without a new tyre placard.
    17's are perfectly safe on a VK/VL as long as they don't touch the body. I have 17's on my VK with standard suspesion and it never scrapes on corners, driveways, speedhumps or bumps in the road.
    Go for it, you'll love 'em
    Kain
  23. #23
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
  24. #24
    VK Berlina Sedan
    Jun 2006
    Hey Guys,
    Just some techy notes worth considering when changing Rims and Tyres on any model Commodore..
    You just need to make sure the rim Offset is the same. You will find that most alloy VN model and upward rims are a different offset or PCD than earlier model Commodore rims, that not only makes them illegal (if you get caught) but also makes your car unsafe as it alters the geometry of your suspension, track etc... There is more to rim fitment than "the stud pattern is right". Better off sticking Calais/SLE or AERO rims for original look and making sure aftermarket rims are the correct fitment for your model commodore.
    As far as rim diametre is concerned you can at most go "plus 2" which means two sizes bigger diameter rim than standard fitment, but only with lower profile tyres so your overall "rolling Diameter" is the same as standard.
    Messing with the wrong wheels will not only be dangerous to the handling of the car, you will be sure that in the event of an accident you're insurance company will not cover you or anyone or thing you have hit... very expensive!!!
    Finally ENV5 is right... VE wheels will not fit ANY other model commodore and the new VE SS is sweet...... love to get one... come on lotto...
  1. brand new vk calais wheels or auscar 16"s for vl calais wheels
    By Majesticknights in forum Swap / Wanted to Buy / Trade
    Last Post: 09-10-2008, 03:47 PM
  2. different width wheels and flat bottom steering wheels?
    By Troy711 in forum VE Holden Commodore (2006 - ?)
    Last Post: 24-09-2006, 05:50 PM
  3. WTB: VZ calais wheels or other genuen holden wheels
    By commy92 in forum Swap / Wanted to Buy / Trade
    Last Post: 29-06-2006, 06:08 PM
  4. WTB-Wheels, any 17inch wheels
    By VRFURY in forum Swap / Wanted to Buy / Trade
    Last Post: 30-08-2005, 11:12 PM
  5. VZ Calais wheels wanted - VY Berlina wheels for sale
    By I just want one in forum Swap / Wanted to Buy / Trade
    Last Post: 19-08-2005, 08:21 PM
