Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: "Start ya Ba*tard!" Kind of a problem but not really..
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default "Start ya Ba*tard!" Kind of a problem but not really..
    Okay atm
    I've changed my fuel pumps over again was VC to WB now back to VC
    Okay shes kicking over atm and firing, but not enough to actully start her running
    I'm currently charging the battery atm as i suspect its getting flat..
    Any ideas on some other ways i could try and kick her over? I tried fuel down the carb but that didnt work, so now im on the battery case...
    ps. my timing is perfect so no going there !!!
    pss. cant clutch, shes an Auto
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    are you sure its getting spark have you tested it? is the fuel pump pumping petty?
    Goon's Avatar
    Feb 2006
    GC. QLD
    Yeah mate ive done both, she zapped me cause i was leaning on the side a bit
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    if you have a spare coil (working properly) start there and work your way thru
    Goon's Avatar
    Feb 2006
    GC. QLD
    I tested the coil to mate, thats how i got zapped. lol!
    I do if a spare lead, i will try that after if the battery fails
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    i would defently get another coil even if it has got spark it might not be strong enough. All you should need is fuel spark and compression to start the car. if the timing is correct have played with the carbie? the idle screw or air/fuel ratio? you might flooded it if you poured too much petty down. that ezy start can shit is good for helping start cars
    Goon's Avatar
    Feb 2006
    GC. QLD
    The aboves all good mate, Well it should be!
    I suspect its the battery , oh well i know in a few hours
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Is it a pionts dizzy?
    If so check the point gap. That sounds like a probable cause.
    VK berlina sedan 202
    Jun 2006
    Make sure you check your float level. Last time I did a carby rebuild, somehow the float level changed and the engine kept flooding. You have to be really accurate with these varajets and the float level.
    Also, its probably a dumb question, but are you pumping or playing with the accelerator to start at all.
    VK EXEC EFI
    Jul 2006
    If you flood it, just hold your foot flat to the floor and keep on cranken. As a general guide to get mixture right wind screw all the way in and then 2.5 turns out. Those settings should at least get her running so u can make your adjustments.
    Goon's Avatar
    Feb 2006
    GC. QLD
    I tried the accelarator pumping bitto start it, i even tried my normal way of starting her...
    Maccar It could be the mixer screw .... if i marked a spot on my screw driver, whatever the mark stops, would i just turn it anticlockwise twice then half of a turn? to acheive 2.5
    Just making sure i do things correctly.
    ps. is that the setting for your ride? just thats yours is EFI
    Goon's Avatar
    Feb 2006
    GC. QLD
    Cheers MACCAR
    It cut my engine noise in half and doubled my exhaust sound
    1993 ED XR6 Manual
    Dec 2005
    I had this sorta problem in my VK...not sure if its the same thing...but it sounds like it. Try a new fuel regulator...I got mine tested and was told that it was just flooding...letting in too much fuel. This could be your problem...either too much or not enough...hope this helps...
    Crossed over to the dark side...
    VK EXEC EFI
    Jul 2006
    Quote Originally Posted by Goon
    Nah i have always had carb cars, just got this one so im a little nervous. 2.5 turns for mixture screws is a sorta standard (i say "sorta" very loosley). Most of the time if the mixture is the problem that will fix it enough to get it running and then you can make adjustments properly.
  15. #15
    Grantis1976 Guest
    If the motor not ur car, then where atre you keeping the battery???
    Keeping the battery on the ground will kill it in a couple of days, then will need charging again. Only needs to be sitting up on a block of timber or similar, so it not earthing !
  16. #16
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks again maccar
  17. #17
    Jun 2006
    Hi,
    This might sound really dumb, but a while ago I rebuilt carby and I was just wondering where the mixture screw was.
    Its a VK with a varajet and I know that the VK varajet is slightly different to the VC varajet.
  18. #18
    Goon's Avatar
    Feb 2006
    GC. QLD
    My mixer is a flat screw located at the bottom of the carb, kind of inside it ... you will have to look for it, where as my idle screw is on the outside area of the carb closer to the accelarator cable.
    Just make sure u know what you are doing mate
  19. #19
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    on a varajet 2, the mix screw is on the left hand side (looking from front)
  20. #20
    Goon's Avatar
    Feb 2006
    GC. QLD
    There may even be a hose or 2 closer to it.
  21. #21
    electric_monk Guest
    Hey I've been fiddling with the float level on my varajet and was wondering what distance you've put between the top of the carby and the top of the float, I put around 8mm at the moment. Although it is a rough measurement.
  22. #22
    Jun 2006
    8mm is the correct float level.
    I found when I rebuilt my carby that you have to be very accurate, so, be very accurate!
  23. #23
    VN Calais V6 S1
    Feb 2006
    Newcastle, NSW
    when i rebuilt mine the paper that came with the carb kit said to have 6mm
    im hungry
  24. #24
    Jun 2006
    My Gregories and Max Ellery manual both say 8mm and mine is running great at the moment, I found that anything else other than 8mm and it would run bad.
  25. #25
    Goon's Avatar
    Feb 2006
    GC. QLD
    Yeah that 6mm by the people who made the carby, but by holden it was more likely and is 8mm
  1. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 06:59 PM
  2. what a "great" start to married life
    By evil_monkey in forum The Pub
    Last Post: 26-06-2008, 08:23 PM
  3. Should I wait for "systemcheck ok" message to start the car?
    By vinni30 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-01-2007, 02:35 PM
  4. Won't start without "start ya bastard"
    By Steven M in forum VL Holden Commodore (1986 - 1988)
    Last Post: 08-11-2005, 12:12 PM
  5. Air con. problem. Something "stuck" in dash.
    By Wombat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2004, 12:48 AM
