Results 1 to 7 of 7
Thread: little help please 3.3 black motor
    305holden Guest
    Smile little help please 3.3 black motor
    i have just put a 3.3 black motor in my car but i have way to much play in the clutch pedded in wont go into give me any so i cant get it in gear ...so i check the arm in the gear box and there way to much play ...im not to sure if the box is off a 3.3 black motor maybe its the wrong thrust bearing in it maybe the black motor has a longer one ...im not to sure hopeing someone could help me out thanksssss
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    The clutch cable might be stretched or the wrong one. What sort of gear box do you ahve, a 4 speed or 5 speed?
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    ok bit more info firstly ?
    was the gearbox in the car originally, or did it come with the black motor you just put in ?
    if the gearbox was already in the car then i assume you swapped all the clutch assembly from the old motor onto the new motor ?
    305holden Guest
    none of it came out of the car put black motor in went to put gearbox and clutch in but to much playing the clutch cable is the rit 1 still in good cond but it looks like a wrong bearing or something like that
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Did the motor u put in atm, have a differernt gearbox to the other car where the motor came from?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Check the pivot adjustment. Also have a look at the condition of the fingers on the pressure plate where the throw out bearing contacts it, and the condition of the throw out bearing where it bears on the pivot fork. If both these areas are worn enough the clutch won't release properly.
  1. FS (SA): EST and Dizzy from VK Black motor
    By HoldenMad in forum Parts And Other Items For Sale
    Last Post: 21-09-2006, 12:20 AM
  2. 202 black motor economy
    By vp_s-pack in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-04-2006, 08:17 PM
  3. VK Black Motor
    By Morgasshk in forum Parts And Other Items For Sale
    Last Post: 20-09-2005, 08:15 AM
  4. WTB 308 BLACK motor
    By bumpy in forum Parts And Other Items For Sale
    Last Post: 14-06-2005, 06:58 PM
  5. EFI for black motor
    By mark 70 in forum Parts And Other Items For Sale
    Last Post: 05-04-2005, 05:10 PM
