Page 1 of 2 12 LastLast
Results 1 to 25 of 32
Thread: engine just doesnt want to work.......
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    Thumbs down engine just doesnt want to work.......
    ok...
    I've got a really frustrating story at the moment. I have tried to rebuild my 202 several times and it doest seem to work...
    Right now i can't get any oil pressure in it... pick-up is fine.. oil pump worked in previuos motor, new filter and it just doesnt work
    Any ideas???
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Did you pack the oil pump with vaseline? Often you do this and it will start to gain oil pressure. Also whats the sender umit like on the oil pump?
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    yes it has been packed with vasaline...... how long would it take to gain pressure doing this
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    shouldn't take long at all.
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    it doesnt work... got any ideas on what else it could be???
    Or how to fix it
    Oh at around 4000 revs could get decent pressure but wud go down when idling if that helps
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    What oil are you running?. That could be a problem.
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Don't get the synthetic stuff, not good for old motors. I think 202s use 20/40 oil. Hmmm need to look in my VB-VK manaul and see what it says.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I wouldnt pack an oil pump with vaseline, I have seen cam shafts damaged this way, the vaseline will disolve when heated but will return to its consistancy when cold, meaning you could clog a pushrod, oil gallery etc.
    When you fit your oil filter prefill it with oil and then fit it to the oil pump. On a 202 you are better to prime the oil galleries, to do this remove the oil pressure sender & fit a tube to the block, I normally use an airline attachment with a hose over the end hooked up to an oil gun.
    Basically pump about 1L of oil though the motor then fill the remaining 4L of oil via the rocker cover, if you tip it in quick enough it will fill the top end covering the valves.
    Next with the spark plugs removed crank the engine over this will pump oil through the engine with minimal load, once oil pressure is achieved then get it ready to start. Whilst cranking the engine over have someone look insid ethe rocker cover and you should see oil filling the top of the rocker arms, this will mean the lifters are pumped up.
    Also when you build an engine you should use some form of anti seize lube like Nulon L90 on the cam shaft, valves, rocker gear etc.
    cheers
    Scott
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    If you do have a plastic oil pressure line, id go and get a copper line instead for about $7-14.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by 9898989
    what oil should i use??
    Use Penrite HPR30, I used to change it at 5,000km intervals on my Hot 202 anywhere up to 10,000km should be ok.
    On a freshly built engine change your oil at about 600-800km, then resume normal change intervals. Dont use a friction modified oil on a new engine after about 10,000km then you could swap to a friction modified oil, but there is nothing wrong with using a good mineral oil changed regularly.
    cheers
    Scott
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    ok jus tried a high volume oil pump to rule out the pump...
    Still got nothing......
    jd hot stuff's Avatar
    jd hot stuff is offline The power of 253
    VB SL 253
    Jul 2006
    Melbourne VIC
    How is it going now, still like crap? are you getting oil to the rocker? if not maybe try looking at the liffters or sumthin down lower than that.
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    Yes there is NO oil is getting to the rocker.....
    Might check the lifters and pushrods tommorow
  15. #15
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    did you fit the adapter from the oil pickup to the block? ive seen this cause similar problems, it screws in tight but wont seal & sucks air into the oil.
    Rob
  16. #16
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    ok well i've decided to pull the engine out
    What should i look for to fix the problem???
  17. #17
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Well before you pull the engine over, you need to begin a process of elimination to work out where to look.
    Are the rockers moving when you crank the engine? If so your cam is turning.
    Is the oil pump being turned, pull the side plate off it and look whilst its being cranked.
    Check your lifters & push rods they may be blocked with vaceline not allowing oil up. Pull oyur side plates off and see there is oil around the top of the lifters.
    Out of interest what was done to the engine?
    Complete strip & rebuild?
    What parts were machined?
    what parts were replaced?
    cheers
    Scott
  18. #18
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    What was done to the engine was....
    Taken out and striped
    New ACL pistons 20 thou
    Crank Grinded
    New Bearings
    New Rings
    New Gas Cam (crow cams)
    New gas valves - Not sure if they are bigger but $400 spent on head
    New high volume oil pump just bought
    Carby overhaul
    New Water pump
    Just converted from EST to the vacume advance Distributor
    Thats all i think
  19. #19
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Default Oil Pressure Probs
    ok...
    Any ideas???
    Is the Skew gear on the end of the distributor shaft connected & seated correctly??Check if any teeth on the on the pump gears are cracked or worn.I'd keep looking round the oil pump area meself.
  20. #20
    Goon's Avatar
    Feb 2006
    GC. QLD
    ^^ That wouldnt be A problem would it?
  21. #21
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok your dizzy dont have naything to do with not getting oil pressure, it will only be involved with ignition.
    cheers
    Scott
  22. #22
    Goon's Avatar
    Feb 2006
    GC. QLD
    Yeah i was thinking along the lines of things firing up and to get things started for other things to happen.
    hey 9898989 when you put it all back togthere did u use a book at all? or just what you thought fit, did.
  23. #23
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    i used the book and this is the second time we have put a 202 together...
  24. #24
    Nov 2005
    I meant the cog gear on the bottom of the pump shaft.Sorry it was early..
  25. #25
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    checked the lifters and had oil in the top of all of them and the pushrods are all clean and weren't blocked
  1. VP Speedo doesnt work then works!!
    By bladerunnerkim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 12:48 AM
  2. My heater doesnt work properly......
    By VQXTC in forum VL Holden Commodore (1986 - 1988)
    Last Post: 12-09-2006, 07:58 AM
  3. brand new key doesnt work. help plz!!!
    By ultimate_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2006, 07:29 PM
  4. steering lock doesnt work
    By garfa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-07-2005, 07:23 PM
  5. Ignition randomly doesnt work
    By Trewman in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2005, 07:38 PM
