I'm hoping someone can help me out with this ongoing prob that no-one seems to be able to answer,my vk calais has a reasonably new recon efi motor in it which has given me grief from day dot. When first started for the day any more than a slight touch of the accelerator causes the engine to run erratic until it warms up & secondly once running if it's left idleing for any length of time it wants to cut out,once driving again it looses power,streams out a large cloud of black smoke and is fine again. Please gimme some answers.![]()
sounds like its running a bit rich possibly.
is the reco motor stock or modified at all ?
Sammy.
http://www.oldholdens.com/
If it's a standard reco is it from hm gem? if it is we provide (i work for them) a 1 year unlimited warranty just take it back and get another
Thanks for the replies,it's a stock recon done by a mate who works for holdens so unfortunately there's no taking it back. I've replaced the fuel pressure reg,fuel filter,fuel pump & engine temp sensor but none of this has made a difference.
could be the air flow meter? is it the same one Before the rebuild if it ran fine before then it probably won't be. it does sound like its too rich or not getting enough air.
i'm sort of thinking too rich, or i don't know if it's possible for injectors to flood the engine or not when it's idling but that's the impression i get. It also has a very black exhaust. Now to top it off the brake pedal has become very hard & when you take your foot off it idle's slower,foot on & RPM's go up,oh & to go with all of that a hissing noise from under dash. AAAHHHHHH!!!!
The hissing sound is a Vacuum leak from the heater controls under the dash right in the centre.The controls operate by a Vacuum connected to the inlet manifold or in your case the injection manifold.Between the 2 heater hoses on the fire wall inside the engine bay you will see a small pipe trace it thru it to the heater/air con controls.Try to disconnect your cruze control, maybe it's at the the end of it's string aswell.......??
Thats NOT the heater controls, they don't use vacuum. If its air con it could be but i think its your brake pedal. My car does this, it means the brake booster is on its last legs.Originally Posted by rsol
yeah i agree, if the brake pedal is hard that usually indicates the diaphram in the brake booster has a split in it, and its probably the hissing noise you can hear too.
i'd be fixing that first, once you have if you still have issues with the idle and black smoke each, remove the little black cap off the top of the air flow meter, under it you will find a wheel with teeth on it, this is what you need to adjust if its too rich turn the wheel clockwise a few notches at a time and see if that makes any difference .... be sure to mark on the wheel (liquid paper or something) where the wheel was originally so if this isn't the problem you can revert it back.
also have a look at the plugs, if they are black thats a good sign its rich, you want to adjust the air flow meter till the plugs are a nice tan colour ....
just so you know, turning the air flow meter wheel anti-clockwise will make the engine richer.
then you have a little allen key bolt on the top right of the air flow meter it may be covered with a plastic cap (red or green) so remove that and this will allow you to fine tune the mixture .... but note this is only the idle mixture, get the main mixture right from the plugs and from driving it before you worry too much about the idle mixture.
Sammy.
I think you'll find that these engines are prone to problems.. you either get a really good one that runs great, or like most people I've spoken to you get one that runs terribly. They're old tractor engines.. what can we expect.. sure, back in the day I'm sure they were pretty good. But I've learnt not to expect to much from these engines at thier age. I'm personally getting rid of mine and chucking in either a V6 or a 253. Let us know how you go.
Thanks for all your replies,it's a great help at least now i've got some things to look at. I suspect the hissing is to do with the brake booster as the noise is coming from around the top of the brake pedal. I'll let ya's know how i get on with it all.
VK's DO use Vacuum to operate the heater/air con controls.I think they were the 1st models to use the system as was the XD Fords.The only cable under the dash is the cable running to the heater tap.The air flow controls are vac operated.My Calais had a hissing noise from the pass side front foot well.It turned out to be the vacuum hose that operates the bonnet cowl exterior air vent.
so far so good, adjusted the air flow meter and it's running heaps better,the plugs have gone from black to a nice tan colour and no more black smoke. Thnx for all your help,especially sammy,ya hit the nail on the head i think.
Not sure if you've fixed the hissing sound yet, but here's another possibity. It could be the hose come off the back of the vacuum gauge in ur dash. The one in my VH did that. My bro has an EFI VK which has the vacuum gauge, so that could be another possibility.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
yep won't start on gas or petrol guy coming to look at it tomorrow! think its the fuel press regulator as it want start on gas anymore help!!!
Driving a ford is like the special olympics....even if you win your still a retard
SPEED KILLS
Drive a Ford and live forever
Sex is good, Sex is golden, Sex is done in the back of a holden.
yeah the spark plugs where about 6months old when we put the new 1's in it started on petrol then 2 injectors r blocked & stuffed & its burning to much fuel & making a funny noise & blowing the black smoke now i finally know wat it is hoo rahh runnin on gas now the guy thought the converter was stuffed but it had the safety activated on it & would'nt start on gas cause no spark from the plugs
will service her myself every 3months from now on! lols out there will be doin a full service next pay day the fuel filter ok thou not even 6months yet as i don't hav ramps just a trolley jack! oil, spark plugs, oil filter,injectors, check battery water levels, degrease big time...needs it
SPEED KILLS
i have the same problem, hissing sound from engine bay, no power assist brakes, but the weird thing is, since i got my timing gear replaced, my cars been EXTREMELY sluggish before 2400 RPM, or about 40kmph, then it picks up really quickly and has power again.. before i did my timing gear, it was a little sluggish but still reasonably quick.. now its just ridiculous
no mate if u hav a hissing sound check the above postSammy's Avatar
Sammy Sammy is offline
Ride: VZ S Ute
Sammy Executive
__________________
Sammy.
SPEED KILLS
still playin up would'nt sart again when its cold needs be started on petrol run about 5mins when switched onto gas it wil start think the gas cvonverter on its last legs either that or air pressure like the air fflow meter.
2 injectors need fixing blowing the black smoke tryed adjusting mixture still run rough on petrol & the plugs r goin black as that is why i think
SPEED KILLS
