Results 1 to 10 of 10
Thread: what fule do ppl run their cars on, Petrol or LPG?
    jd hot stuff's Avatar
    jd hot stuff is offline The power of 253
    VB SL 253
    Jul 2006
    Melbourne VIC
    Default what fule do ppl run their cars on, Petrol or LPG?
    Hey every one just wondering what fule ever one is using on there vb-vk rides, and what do you think is better. I think that LPG is better on the older engines if you get the correct stuff done to them you can still get heeps of power, and it also helps your pocket out in the long run.
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    I'm with you VK_308
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VY 'S' Pack '03
    Jul 2005
    Tanjil, VIC
    I got Gas and think it is worth it...
    My car still runs good enough.. plus for just under $20 i can get 300 -350 Km
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    VK berlina sedan 202
    Jun 2006
    EF Almost Turbo
    Jun 2005
    ive used both.. ive found that 202's run better on LPG than regular unleaded.. they are also alot easier on the wallet
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    VB SL 253
    Jul 2006
    Melbourne VIC
    Since i started this thread and never mentioned what i have i think i will now. At the moment my cars on dule fule but soon im converting to straight LPG, its also good as ive got a 90L tank. I just hope there is nutthing wrong with it since its 2 years out of date.
    Aug 2005
    I have LPG (duel fuel), i find that it runs smoother when i do change it over to petrol (i have to use the 98 octane stuff).
    The only problem i find is that i only get 200kms out of a tank of gas (prolly a bit more if ran it dry, but don't want to risk it).
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    If you were to change it to straight gas, use a research system, probably the most efficient... The throttle boby mounts to the base of a 4 barrel holley, therefore, you'll need to get either a holden/rochester manifold off a red 308 or blue 4.2/5.0L, but fitting a valve lube drip system is also reccomended...
  1. Which petrol is best?
    By CHARGEDVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-01-2007, 02:43 PM
  2. internal fule pump
    By VN-SV-89-LE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2006, 08:23 PM
  3. does anyone else have gas/petrol
    By SYM35 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-08-2006, 04:18 PM
  4. Out of Petrol...???
    By wbd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-01-2006, 10:20 AM
  5. Petrol Help
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-08-2004, 10:24 AM
