Results 1 to 8 of 8
Thread: VH Commodore carby problem?
    Oct 2005
    Default VH Commodore carby problem?
    My VH Commodore wagon has developed a problem. It is a 2.85ltr 4 speed manual all standard.
    Vehicle starts first time every time from cold.
    Running standard unleaded with flash lube
    Under heavy acceleration it coughs and splutters and eventually dies, leaving a fuel smell. I cannot restart immediately.
    Under normal driving from cold start I can drive for about 15 minutes no problems then vehicle dies, leaving a fuel smell. Attempting to restart can be a problem sometimes it does and it will not hold idle.Sometimes it will sound like a backfire under the aircleaner.Sometimes it wont and I wait and restart after about 10 minutes.
    Items that have been checked and replaced
    Air cleaner
    Ignition leads
    Spark plugs- New plugs have a carbon(black) deposit on them after this problem occurs (cleaned and reinserted)
    Distributor and rotor.
    What is next?
    This is driving me nuts
    If anyone can assist in solving my problem with a how to do description. It will be most appreciated.
    VN S Pac VH SL/X
    Jul 2006
    could be the jets in the carby are blocked. have you changed your fuel filter?. I dont know much about these but I know the slightest bit of crap in the carby will affect it big time. Carby rebuilds are fairly expensive maybe look at upgrading it to another type e.g. a holley
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Could be your timing
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    tigervh is offline SS.....smokin....!
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    Sep 2005
    Newcastle
    Sounds like either the fuel pump or fuel filter. another possibility is the needle and seat.
    Oct 2005
    I havent replaced the fuel filter.
    Timing is set a little out to compensate for pinging
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    have you tried to run the car on PULP instead of the regular unleaded?.
    Oct 2005
    Sep 2005
    Newcastle
    I,d replace the pump before anything else.
  1. carby problem maybe?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-01-2007, 09:24 PM
  2. VH Commodore carby-automatic choke
    By bigfella99 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-08-2006, 09:24 PM
  3. Vh Commodore- Fan Problem Plz help
    By pinguino in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-04-2004, 06:09 PM
  4. 81 Vh Commodore Carby Advice Sought
    By rossbl in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-03-2004, 09:46 PM
  5. 81 Vh Commodore Carby Advice Sought
    By rossbl in forum Site Feedback / Site Problems
    Last Post: 07-03-2004, 07:39 PM
