Results 1 to 15 of 15
Thread: Transmission Installation - Need Help
    Mr Robbo - The General's Avatar
    Mr Robbo - The General is offline Defect Notice Attractor
    VS II Statesman 5L
    May 2006
    Newcastle, NSW
    Default Transmission Installation - Need Help
    Hey evry1, im trying to bolt in a 5 speed into the vk, (she was an auto) , im up to putting the box in, just having a bit of trouble. I have gotten as far as pressure/clutch and spigot bearing on, having trouble with getting the box on. it slides in almost the whole way on and stops about 10mm short. just wondering what could be the problem.
    My Car is my OTHER child
    EF Almost Turbo
    Jun 2005
    what sort of gearbox you putting in?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Have you got the right flywheel on for the box? The input shaft the correct type?
    VS II Statesman 5L
    May 2006
    Newcastle, NSW
    yep, its a M76 box, everything is stock on it, hasnt been touched, all the clutch parts and flywheel are right
    VK Calais
    Feb 2006
    I'm doing the exact same thing mate, at the same stage aswell. Did you have fun with your pedal box? I did....
    I'm yet to buy a pressure plate and the spigot bush, but I'll let you know if I run into the same problem. Hope all goes well
    VS II Statesman 5L
    May 2006
    Newcastle, NSW
    yeah good luck, i havnt done the pedal box yet!! lol
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Did you use an alignment tool to make sure the clutch plate is centred properly. If the clutch plate isnt exactly centre you will not be able to get the front shaft to fit into the spigot bush.
    Mar 2004
    Yep "Treecutter" has it.
    Make an alignment tool. I dodgied one up by using a large drill bit that the blunt end fitted into the spigot bush nicely, then I wrapped tape arond the drill shaft where the clutch plate was until it was a nice fit in the hole in the clutch. It just holds it in place while you tighten the pressure plate bolts up. you then remove it and the gearbox shaft should slide through, you may need to get a mate to move the engine pulley a bit to enable the splines in the clutch and gearbox front shaft to align, if it still refuses to go in. If you have access to a lathe, wizz one up out of an old broom handle, it doesn't have to be metal.
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    i agree, align the clutch plate ... you can do it by feel which is how i do it as im too lazy to buy an aligner, but it sometimes takes a few attempts
    VS II Statesman 5L
    May 2006
    Newcastle, NSW
    hey every1, cheers, just letting u know i got it all in, yes i did use an alignment tool first up, the problem turned out to be the spigot bush not gone in all the way :@, anyway its all in now cheers every1
    VK Calais
    Feb 2006
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Hi Guys,
    Just on the alignment tool topic if you want a great alignment tool cheap go to a gearbox reconditioning place and get a buggered input shaft out of a gearbox, make sure the splines suit your clutch plate & you wont get a better alignment tool.
    cheers
    Scott
    VS II Statesman 5L
    May 2006
    Newcastle, NSW
    Quote Originally Posted by Wrayza
    I'll remember that when I do mine, cheers! (saves me asking lol)
    Yep mate, make sure its RIGHT IN THERE. or it stops the box short by half an inch lol. and once you've got to getting the box on, u dotn wanna take it all out to get to the spigot. Use a socket about the same size and hammer it home.
    1983 VH SLE SUPERCHARGED 208
    Apr 2004
    Ellenbrook Perth W.A.
  15. #15
    Vk executive 1985
    Sep 2005
    try using a broom handle to line up to line it all up so that the spline can slide in easier...there definatly not fun to pull out but a little persistance and u will get there , we just replaced the clutch on a mates vl , so i know how u feel haha
    good luck tho !
    cheers
    bretto
  1. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  2. VS amp installation
    By vsMick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 02:22 PM
  3. Amp installation?
    By Philthy in forum Car Audio
    Last Post: 20-09-2006, 07:20 PM
  4. CAI installation
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2006, 11:07 PM
  5. Sub installation
    By navyboy85 in forum Car Audio
    Last Post: 08-02-2005, 10:35 AM
