Results 1 to 8 of 8
Thread: V8 exhausts
    the lightning
    Jun 2005
    under the Southern Cross
    Default V8 exhausts
    what does everyeone run?
    I'm thinkin of going for twin 2.5" into a 3'' big bore, been told it will be a lot louder than my current system which is rather noisy as well, almost sounds like a nascar out on the freeway.
    will have to run a resonator but no chromed milo tin fart cannon for me thanks.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    I have extractors, twin 2inch into single muffler then 2,5 inch out to the rear. Mine is loud, but not over the legal DB limit, thank christ.
    Thats another thing, its got to be under 98DB or its not legal
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Mine is like SL/E nut's.
    I have twin 2 inch into the first muffler and then single 2 1/2 inch out into the hot dog muffler and 2 1/2 inch out from that.
    If my exhaust ever blows a hole, I am going to replace it with a complete dual exhaust. Eh, maybe.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Im running Pacemaker 1 3/4" primary headers into 2 1/2" collectors then twin high flow 2 1/4" through twin cats into a single 3" mandrell bend though a single 3" muffler & a huge hotdog.
    The exhaust is flanged at about 7 position allowing easy removal of sections, all painted in heat proof paint.
    more info on my site.
    cheers
    Scott
    the lightning
    Jun 2005
    Quote Originally Posted by vkberlina
    cheers
    Scott
    that sounds awesome, wouldnt have been cheap though, I;m going 2.5" to the muffler then a 3" dump pipe out the back, mine will be flanged in 3 or 4 spots.
    VK group A and VL Calais
    Jun 2006
    You might wanna put a resinator on with a 3". Speaking from expereince. Although I have a heavily worked 308/ stage 3 cam setup for drags and was way over the legal Db imit... Cuts the incar drone
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Mad work vkberlina
    Does the cat make a difference?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Thanks, well i have 2 cats and have to run them as the car the engine came out of had them. The are high flow cats for an LS1 so I there will be any obstruction to exhaust flow.
    I havent driven the car with the efi 5l very far, only in & out of the shed, off & on the trailer etc. It does sound sweet, it wont pass the noise test by a couple of DB as it is but I have a silencer to install which will fix that problem.
    cheers
    Scott
  1. Need help on exhausts..
    By Soybean in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-07-2006, 10:36 PM
  2. exhausts
    By ando78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-09-2005, 03:13 PM
  3. Exhausts
    By xstatic in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2004, 09:13 PM
