This may come across as a stupid question, but I'm gonna ask it anyway... how do you replace the ignition module on a Black Carby 202 (VK)? please keep it pretty basic if possible as my head doesn't work quite as well as it used to... (scary thought considering I'm only 22)...Please help me!
why is monosylabic such a big word???
Well if its running the EST system the computer controls the spark timing, if someone has seen the light & removed the EST and installed an electronic dizzy you need to remove the dizzy & unscrew the 2 phillips head screws remove the diecast cap off the size unplug the ignition module, put heat transfer paste onto the new one and plug it in, reverse the uninstall process.
cheers
Scott
cheers for that scott... take it easy man!
