Results 1 to 18 of 18
Thread: key barrel removal - HELP
    EF Almost Turbo
    Jun 2005
    Default key barrel removal - HELP
    Hey guys
    well a BIG thanks to upweapn for comin over n having a look at the VC.. much appreciated..
    now, i need to know how to remove the key barrel from the steering column that has a full metal jacket..
    s0sage gave me directions (another big thx to him too!) however because of the FMJ they dont make sense..
    any help guys?
    DaZ
    Project: Shifty1 commences Feb 2007
    The_Monk says:
    im a leech
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    yeah this is hard i changed one on my old vk and it turned out alright but i couldn't the steering lock to work. Someone might be able to explain better as its been almost 2 years. (undo battery first) first thing remove steering wheel 2 unbolt the whole steering column under the dash 3 remove the turn indicator bit 3 screws from memory then tunr the keys on. and there should be metal bar in a plastic slide clip thing (yeah i know my stuff) i just broke the plastic bit in mine as i found almost impossible to get it out. I had the whole big cylinder part with the barrel in it already (out of a VC). if its the you just want to replace someone prolly knows how to do that
    EF Almost Turbo
    Jun 2005
    Yeah, we tried getting the steering wheel off.. but without a whel puller its hard.. and we didnt strike the centre nut.. we were trying to hit it toward us..
    DaZ
    The_Monk says:
    im a leech
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    I remember there was also a couple of screws on top to loosen the plastic slide bit which is why i dropped the column down. Steering wheels are a prick to get off youtry loosening the nut and driving around the block and it might come loose bashing it doesn't always work. I bought a puller from super cheap then took it back and said it didn't work after i was finished to save me money.
    EF Almost Turbo
    Jun 2005
    i would drive it around the block but it doesnt start...
    DaZ
    The_Monk says:
    im a leech
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    EF Almost Turbo
    Jun 2005
    yeah.. that spring broke n its jamming it up now..
    DaZ
    The_Monk says:
    im a leech
    EF Almost Turbo
    Jun 2005
    it wont turn far enough to start..
    DaZ
    The_Monk says:
    im a leech
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    EF Almost Turbo
    Jun 2005
    no.. it doesnt move far @ all..
    DaZ
    The_Monk says:
    im a leech
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Pub24/7
    A really ethical thing to do.
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Thanks slim i'm a top bloke who doesn't like big rip-off places like super cheap they make enough money what's $10 to them? they'll just re-sell it anywayi
    White vc can you get it to accessories ?
    If you can you might be able to run a wire from the + terminal to the starter motor to start it.
    If you can't i'd say it a mission to get the barrel out.
    EF Almost Turbo
    Jun 2005
    it doesnt make it to the first click.. im gonna look into getting a puller..
    DaZ
    The_Monk says:
    im a leech
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    I can tell you how to start your car without the key mate ifthat helps, though i hope your steering wont lock on yah, but through pm.. theives these days
    ps. ill take a quick look at my book.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  15. #15
    Mar 2004
    I had trouble, the manual said insert a pin in the hole, I could not find where this hole was any where. It turned out that the alloy had not been cast properly and there was a thin layer of alloy with just a small hole visible, I used a screw driver to scrape it away and enlarge the hole. It was years ago and a bit faded in the memory now. hope this helps
  16. #16
    Mar 2004
    Hint. Go a buy a steering wheel puller, they are cheap and will save you form damaging the steering column. In a crash if your body is thrown on to he steering wheel it collapses toward the dash to absorb the impact and not smash your chest. If you are use excessive force like pulling or hitting it while trying to remove the wheel you can damage it. (I did)
  17. #17
    VX S Series 2
    Jul 2005
    Coffs Harbour NSW
    As 9C1pack said. The casting covers a hole that you push the clips of the barrel in, which allow you to pull the barrel out with minimal hassel. Just break the casting with a screw driver.
    When you pull the barrel out take note of the position that the gear is in, which is on the end of the barrel, other wise you will have trouble with your ignition locations.
    WILL THE VK EVER MAKE IT BACK ON THE ROAD
  18. #18
    EF Almost Turbo
    Jun 2005
    Alright guys.. had another look today.. turns out the barrell is fine.. it was the switch it connects to.. fell to pieces when the cover was removed.. all fixed n running.. BIG thanks to ucweapn & s0sage!!
    DaZ
    The_Monk says:
    im a leech
  1. Ignition Barrel removal/repair
    By CraigAB in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-10-2007, 08:03 AM
  2. ignition barrel removal
    By k191350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2005, 02:25 PM
  3. ignition barrel removal
    By blowera1 in forum V6 Development And Modification
    Last Post: 16-07-2005, 10:48 PM
  4. Ignition Barrel Removal Help
    By v8bike in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-07-2005, 11:27 AM
  5. need help with ignition barrel removal
    By paco in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2005, 12:14 AM
