Hey guys
Behind the horn button.. how is it MENT to look.. mine is missing a piece (doesn't reach far enough to activate the horn..) the car isnt drivable without it..
Thanks
DaZ
Project: Shifty1 commences Feb 2007
The_Monk says:
im a leech
Standard steering wheel??. Hmmm you might need to explain a bit more.
sorry... yes its standard..
theres 1 wire coming out of the steering column.. i plugged it onto the back on the horn button.. but when you press it nothing.. we had a closer look n it doesnt reach anyway near far enough.. so we are presuming something is missing.. but we arent sure what it is![]()
DaZ
The_Monk says:
im a leech
Hmmm a pic would be great, i can tell you that!. But I don't thing anything is missing. I wonder if the horn contact ring is dirty. Might need to take my dads VB steering wheel off, take pics and have a poke around.
hmm..
we put the nut back on the wheel.. and some little black one as well.. plugged it in.. nothing :S
EDIT: Goon, thx but if we touch the horn wire onto the metal part of the column it sounds..
DaZ
The_Monk says:
im a leech
the weird bit.. if you touch it to the bolt where the steering wheel sits.. it works perfectly.. otherwise.. on the button.. nothing.. oh and btw ys it was working, and it still does.. :P
DaZ
The_Monk says:
im a leech
You really get the uncommon problems mate, i looked in my book again and nothing to help ya out with
" If you do post a pic : Is your steering wheel tan? with the symbol in the middle? If so how did u take the cover off? and ill take a picture of mine if you have a photo of yours easy to compare then.
Thats the horn setup at the moment..
DaZ
The_Monk says:
im a leech
I tried to remove my horn button/cover with a flathead before but its stuck in tight and ill take a chunk out if i try
looks like its scrwed from the inside? so i would have to take my steering wheel off to remove the cover? if so sorry mate
EDIT** the black wire connects to the side on the right? "bottom photo" and it doesnt reach?
Looks like in that last pic the connection onto the horn pad is broken, thats where the black wire connects too. If thats correct you need a new horn pad.
umm, this may sound like a really basic solution, and i apologise if this is no help whatsoever.
On mine, i changed the steering wheel and when i put the old one back on i was racking my brain trying to sort it out, turns out you need to put the whole thing together (screw the horn pad onto the steering wheel), this sorted out the problem i had.
So in short, plug the wire in, SCREW to horn pad into place, and give it a whirl, as i said, it solved my problem, i assume the screws acted as some sort of ground.
Yes, its embarrassing.. but a simple TIGHT screw to connect it fixed it..
also.. goon.. just use the 2 screws behind the wheel mate..
DaZ
The_Monk says:
im a leech
Cheers mate, i'll have a look at mine after 9am. Then ill post a few pics for yah if i get the thing off..
but yeah screws behind it cheers
EDIT - badluck so far mate, some of my tools have gone walkabout and i'm not happyI'll seewhat happens after midday, i can't even find my mini flathead
damn.. good luck mate :P
DaZ
The_Monk says:
im a leech
Good to see you guys got it sorted out![]()
My problem is fixed.. thanks anyway.. the old girl is back together, got a tuneup today n she is running sweet![]()
DaZ
The_Monk says:
im a leech
sure does..![]()
DaZ
The_Monk says:
im a leech
