Hi probably a stupid question does a 186 red yella terra head fit on a 202 blue. If it does is it worth it as I know the blue motor got better flow then the reds anyway. Cheers
Well, a head off a red motor does fit on a 202 blue, and yeah it does work, my old VH had the same set-up. The only trouble I had, was getting the idle right, but after some modification, and playing around, it was all good!! And it went really well. Never had a problem with mine.
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
186 heads would throw your compression through the roof mate....
MaT
Originally Posted by garth
Also a red head can't fit a blue motor, the water jackets area all in the wrong spot. You can but a blue head on a red motor, but not the other way around
Cheers, might buy it anyway its only gonna be like $50 probably sell it on ebay.
umm, yeah you can bolt it up... i've had a blue 202 with a red 186 head... compression was high, but with the right timing and fuel, it was fine...
I'm pretty sure 202s and 186s share the same combustion chamber volumn. The 202s used dished pistons to lower the compression wheras 186s had flat tops. blue and red heads are interchangable with minor modification. You will have to use red motor manifolds.Originally Posted by HoZy
I know its an old thread but i did the very same mod myself. If you can use a drill and tap a hole it can be done in 30mins![]()
You wouldn't need a cert as long as it complies with the emission control from that era.
Yea no certs needed. Paint it blue... the cops wont know the difference![]()
Hey while on the topic of yella terra heads.....is there many around to suit blue motors? I've seen lots around for red motors, but haven't come across one yet for a blue head.
When I finish my motor I rekon the next thing will be a yella terra head...but want one to suit a blue motor.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
