Results 1 to 6 of 6
Thread: Timing on a Black 202
    VK berlina sedan 202
    Jun 2006
    Default Timing on a Black 202
    Hi guys,
    Can anyone please give an idea on how to adjust ignition timing on black 202 in a VK.
    I have a timing light but I don't know what to do and I don't understand when people talk about x amount of degrees etc.
    So, can anyone give me an idea on how this is done.
    Thanks
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Make sure your spark plugs are all firing and warm up the car and connect the timing light to spark plug one lead. Point the gun to where the timing scale is on your harmonic balancer. The timing for a 202 black, it is 6 degrees BTC at 850 RPM. Unbolt the distributor bolt and slightly rotate the distributor and bolt back up and check again if it's out. You shouldn't need to check it anyway if it's running fine. It will likely be spot on.
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    The spark timing on a 6cyl est computer car cannot be adjusted...its set and no amount of moving of the distributor will advance or retard the timing...all it will do if you turn it a lot is stop the engine because it pushes the firing on to the next cylinder on the distributor cap.
    The fuel injected 6cyl vk cars used a vh type distributor so they can be adjusted but a normal carburetor type 6 cyl car cannot on a vk
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Jun 2006
    I forgot to add that the EST module failed a while ago and a blue motor dizzy and other stuff has been put in.
    I know my timing is out because it was played with a few months ago and it hasn't been properly adjusted.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I forgot about EST.
    In that case 85berlina, do what I said. Make sure the timing mark is pointing at 6 degrees BTC and have your car running at 850 RPM, warmed up and all plugs firing.
    Jun 2006
    Thanks Slim.
    I'll be doing that very soon.
  1. 308 timing help
    By 308commodore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2010, 03:37 PM
  2. Replies: 73
    Last Post: 04-02-2009, 04:54 PM
  3. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  4. vs v8 timing help!
    By mean in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 03:52 PM
  5. 308 black motor timing chain removal
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-07-2006, 10:41 PM
