Results 1 to 23 of 23
Thread: removing fuel pump from vk calias v8
    Vk calias
    Aug 2006
    Default removing fuel pump from vk calias v8
    How the hell do i get the intank pump out, please dont tell me i need to take the tank out
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Ok then i won't tell you! . There is 2 ways. One is take the tank out or ther other way. The other way make sure you have no fuel in the tank, jack up the rear of the car, place jack stands to make it safe. Now when the car is safe in the air get a flat blade screw driver and a hammer and and tap the fuel outlet(or fuel pump, its in the same spot) either clock wise or anti clock wise. Only need to tap it a few times and you should be able to get the intank pump off.
    Vk calias
    Aug 2006
    I tryed tapping it with a hammer i figured it might have screwed out. That didnt seem to work, maybee need to hit it harder
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    You only need to go so far and it should pop out. What sort of fuel tank is it first, a VB-VK type?.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    They don't but ported might have put on in or the previous owner has
    Vk calias
    Aug 2006
    thats strange i just assumed it would have been standard as the rest of the car is part from the gas system. Best i take the tank out and have a good look at it
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Default V8 Internal Fuel Pumps
    Quote Originally Posted by Pub24/7
    I didn't think v8's have a pump in them only efi's
    V8 VK's have the internal fuel pump similar to the EFI's.My Calais runs both, the fuel tank 1 & the engine mounted type.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well how many wires are on the fuel tank on the fuel outlet?. If its just one well its NOT an electric pump. If there is more than one wire there could be an intank fuel pump. Usually the fuel pump is on the block, at the front on the drivers side, just below the alternator.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by 308vkcalais
    Nope VK V8s never got the internal pump, I know HDT was playing around with a few in the VK series, wasn't untill the HDT VL V8s got the internal pump, Holden still used the old mechanical pump on the block.
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by SL/ENUT
    Well my VK Calais 308 is pretty stock and it has an electric in-tank fuel pump. As the manual says, it also has the special fuel pump relay in the fuse box.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Hmmmm thats strange. They must have it then. Although the one owner 1985 one i looked at didn't have one.
    I had a look in my VB-VK parts book and it says that they do have them.
    So i am wrong and 308vkcalais is right
    Nov 2005
    Default V8 Fuel Pumps
    Do your info b4 you post.You don't drive a V8 VK to know what's what...!!We had this rot 2 weeks back when in a diffrent post you INSISTED the VK's had no Vacuum operated Air/Heater Controls & they do.Do us a favour & go buy a V8 VK so next time you post you know what it is you're talking about...
    vk383
    Sep 2005
    Vk calias
    Aug 2006
    lol settle down guys. Ok so we had come to the conclution that it does have one in the tank now how the fck do i get it out??
  16. #16
    Nov 2005
    Default VK Fuel Pumps
    Quote Originally Posted by ported
    Ok, here's my old SL Fuel Pump, well sender coz it dun have an internal pump(for the benefit of ppl whom don't know)so dun look for the internal pump as it is the old Mechanically drawn type on the SL's.The Sender unit face, we'll call it twists into the tank clockwise or anticlockwise, if your left handed like me as shown in the pic.The tank itself has the notched out cutout for the pump body, sender face wateva you wanna call it.It also has a rubber ring you'll need to replace it wif & sum gasket goo for a nice waterproof seal.So grab a good meaty bladed flat headed screwy & tap it around, but dun kill it & make sure you're low on fuel or you'll get a drink..
    Attached Thumbnails Attached Thumbnails removing fuel pump from vk calias v8-fuel-pump-tank-sl-.jpg
  17. #17
    Vk calias
    Aug 2006
  18. #18
    the lightning
    Jun 2005
    under the Southern Cross
    getting back to the in tank pump thing, if theres a 3 pin terminal on the sender face with a rubber insulated plug going to it then its the electric in tank pump, one of the wires is violet, cant remember the colour 0f the other two.
  19. #19
    Vk calias
    Aug 2006
    Quote Originally Posted by Cane_It
    Black and a yellow earth
  20. #20
    Nov 2005
    Thumbs down SL/ENUT reply
    In response to SL/ENUT's private message to me claiming "mate I've worked on heaps of VK V8's & not all of them have the internal Fuel Pumps" well you're wrong because V8 VK's had internal fuel pumps fitted from the factory.
    Now to your second wrong claim that the "vacuum operated Air/Heater controls are only on VK's with Air" is crap aswell because the Vac operates the demister, floor vent, Bi-level vent & exterior bonnet cowl vent, so it has shite to do with having air con fitted or not.So you're wrong twice again cobber..
    Thirdly to another one of your incorrect claims that the "VL's use the old VB type cable set up for the Heater/Air" is also way off the mark because Holdens & Fords began using the Vacuum operated Air/Heater controls from 1984 onwards claiming it was a break though in technology.The only thing 'RARE' about you mate is that you are RARE-ly right.
  21. #21
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    correct... why would holden use vaccuum operated heat/cool controls in the VK, then change back to old school in the VL, then change back to vaccuum in the VN... mmm... 308vkcalais is spot on, they started using it in 1984, including the VK...
  22. #22
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well my mates old VL must of had some dodgy backyarder replace his heater then, cause it was just like what my dads stock VB heater set up is. The whole lot was the same.
    Same with the VK V8s i have worked on, someone must of replace the fuel tank, cause the ones i worked on didn't have the intank pump, and it puzzled me.
    Oh and 308vkcalais, I didn't send a Private Message. What i used wasn't that. It was the Rep feature(the scales on the top right). Also i'm not rare, my car is.
    One last think, thanks for pointing out that i'm wrong. We all make mistakes. I hope that we can get along on this forum in the future
  23. #23
    Nov 2005
    Cool mate.I don't have issues about it.My mistake for calling your reply thing a priv message, I dun know how to drive this site yet.I'm still learning.Like what we all come on here for.It's a fab site to share info, gain knowledge or simply to get ideas from others for your own ride.In hindsight howeva, I believe it's importanat that the info coming ova is correct, in particular for the sake of the youngsters whom dun have any idea.Good on the young fellas for having a go turning spanners.That's how I started out wif no tools til my Wife bought me a timing set for Xmas & the outlaws, the same yr got me sum Sidchrome spanners.The 1st stages of my tool kit.A long time ago now....in a galaxy far, far away.. sorry wrong story..(old age)
  1. Wtb: Fuel Pump
    By Goodloox_Nogutz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-04-2008, 01:52 PM
  2. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  3. VN Fuel Pump ?
    By snowcatz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 10:07 AM
  4. removing innards from water pump
    By closer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-12-2005, 06:41 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
