Results 1 to 7 of 7
Thread: Gasket help asap
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Gasket help asap
    Hey all
    Theres a leak in the back left hand side of my carby if someone was to face the front lookin on, i was wondering which gasket this would be ? its the one that sits between the plate and the carby's underbody.
    thanks in advance
    please an answer asap i'm kinda on a deadline of 3pm today
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VH V8
    Sep 2005
    Goon's Avatar
    Feb 2006
    GC. QLD
    yeah just a varajet2 carby, with a plate in the middle then the manifold. leaks fuel in one corner and i dont want an engine fire
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    Take Your Carby Off And Fit 2 New Carby Base Gaskets, One On Either Side Of Your Black Insulator Plate...
    VH V8
    Sep 2005
    yeah, figures that!
    i would say to replace both the gaskets on top and under the plate because if you take it apart to replace just the top one, you will take pressure off the bottom making it not seal properly.
    i cant think of any other gaskets that it would be. as long as its not the actual fuel line going to the carby...
    Goon's Avatar
    Feb 2006
    GC. QLD
    thanks lads
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I should point out especially to Goon, that if the base gasket is cactus and causing a leak, then there would be major vacuum problems causing the car to not idle and probably a number of other problems.
  1. gasket tip
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2010, 09:37 PM
  2. Throttlebody Gasket?
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-03-2007, 08:25 AM
  3. Is my Head Gasket Gone????? Please HELP
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2006, 10:45 AM
  4. blown gasket?
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 04:30 PM
  5. VRS Gasket Set?
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-04-2006, 08:02 PM
