Results 1 to 5 of 5
Thread: ethenol blend fuel in the good ol 202 black?
    hocus Guest
    Default ethenol blend fuel in the good ol 202 black?
    would it do much for performance?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    As long as the fuel has sufficient octane to cover the engines requirements it should be sweet.
    There have been reported issues with carbie cars & ethanol based fuels, also the alcahol tends to absorb moisture so if the car is sitting around you might get water in the fuel over time.
    The other issues have been with the alcahol destroying fuel lines, so keep an eye on your fuel lines, if you do replace then use good quality EFI line it will last longer. Also if your fuel lines start to decay replace your fuel filter there might be crap in it too.
    Personally I wouldnt have a problem running ethanol based fuel in a car of mine, mind you my cars are EFI. I havent run ethanol based fuels in my cars recently as one sits around too much, and the other I dont drive past any servos selling the fuel.
    cheers
    Scott
    VS Stato SII L67 S/C V6
    Apr 2004
    I would avoid it until you cant, ive seen the photos of testing done by the govt. on VK's, and it wasnt pretty.
    As vkberlina said you are probably going to have less issues with the better EFI lines etc, but i still think its nasty stuff.
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    as far as performance goes it seemed to work just as good or better in my car, i used it back as carbied motor and then converted to EFI ... i'm all for it, 100% ethanol fuel i say
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    E10 fuels have corrosion inhibitors in them to stop your fuel lines etc degrading over time.
    I use it at every chance in the VK, and the VK loves it. I avoid E10 95 - noticeable drop in performance - the E10 98 (Boost) goes nice though
  1. Bad fuel smell/Exhaust all black
    By mrvxgen3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-09-2007, 06:59 PM
  2. Will It Blend
    By holdensupporter2005 in forum Jokes/Humour
    Last Post: 22-01-2007, 01:34 PM
  3. is it safe to put 10% ethonal blend in my VY Calais?
    By missmoo55 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-12-2006, 10:35 AM
  4. Black Smoke = Fuel ?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 09:21 PM
  5. Ethanol Blend E10 fuel?
    By Wombat in forum General
    Last Post: 26-10-2005, 10:43 PM
