Results 1 to 16 of 16
Thread: how to beat rust?
    VH SL/E 304 (injected)
    Jul 2005
    sydney
    Default how to beat rust?
    my old girl is pretty sweet when it comes to the rust department but i can see signs of it starting to happen in a few places.
    there is some electronic devices out there that claim to slow down/stop gthe rust prosses.
    do these devices work??
    whats the best way to stop the rust?
    thanks
    Aug 2005
    Good old fish oil is what i have been recommended to use, and i haven't had any rust come up on me, mind you, living in canberra pretty much makes the rust a non-issue.
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    yeh fish oil is the best and cheapest by far..... those electronic rust inhibitors only really make a difference when the car is kinda newish before the rust gets a chance to settle in
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I go against the norm here, I wont use fish oil, reason fish oil over time dries hard, for paint etc to adhere correctly to a surface it needs to be primed & preped correctly else it will crack & craze from expansion & contraction of heat & cold. Condensation & moisture will collect in theres cracks & crazes and basically rust the car from the inside out. Fish oil needs to be reapplied periodically else the above will occur.
    Personally I use a product called WAXREX by Mobil you buy it in a 4L tin, its basically industrial petroleum jelly being a petrolium product it repels water & moisture. When heated it turns to a liquid, when cooled it turns to its original state. Why this is good is on a hot day it will travel into places you will never have a hope in hell of spraying any other product into.
    It also seeps into body seams and travels via a capilary like method into all kinds of places.
    Ok the downsides of waxrex.
    On a hot day it melts excess will leake out of all kinds of weird places, I have had it come out around door locks, door handles, body seams. It looks a bit untidy when dust collects in it but is easily wiped off and wont damage paint. It will leak out through door seams etc & just needs to be wiped with a soft rag.
    Next one, this can be really bad, dont let it stay on rubber for extended periods of time, depending on the type of rubber it will soften it & could cause it to be damaged easily.
    I have been very happy with the results over the last 8 years, done a number of friends cars, never to see any rust appear in them.
    The other product I would consider using is a lonolin basic product, I saw tests that were completed in conjunction with landline & the results were great, unprimed bare steel coated in lonolin based products were left outside next to painted, un painted etc products for a period of about 12 months after the test the one coated with lonolin was wiped down to see the steel look exactly the same as pre coating no signs of any corrosion.
    cheers
    Scott
    VP Exec
    May 2006
    Quote Originally Posted by MontieVHSL/E
    yeh i no wot u mean, im the same, been rust free til the last couple of months where i can see a bit of orange under the rear window and a little bit of rust starting under the front window, im thinking it would be better to take it to a panelbeater and get the rust cut out, that way i no its gone and then could use some of these other products to make sure nothing else happens
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    If you got patience and are up for the hard work, id go with rust converter.. depending on the job and size.. some like the boot id look at replacing.
    I'm keen to hear on postive notes about the electric items.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    Quote Originally Posted by Goon
    im keen just to hear of them. What are they? how do they work?
    VP Exec
    May 2006
    VE SSV
    Sep 2005
    Perth, WA
    i know this isnt the VT -VX forum but a little info for you guys
    the electronic device is mounted in your engine bay (commonly) and sends and electric pulse through the metal on the car and apparantly repels rust...i have seen it on my mates work car..a BA F*RD 1 tonne ute and it has rust on the B pillar as you open the door and the car has been washed twice and spent most of it life it the warehouse at the job....
    its been on since new and he has had the car since new...considering the limited water on it and the fact its in perth so moisture isnt a huge issue..its SH*T..yet to hear anything good about it.
    mums vp from new had the BEAM rust proofing applied (like a paint) before picked up from dealer....not a hint of rust on the car and its 14yrs old. the paint is fading on the bonnet but no rust. LOL
    VK berlina sedan 202
    Jun 2006
    Does anyone know if using that wax stuff is any good for underneath the window rubber?
    VP Exec
    May 2006
    Goon's Avatar
    Feb 2006
    GC. QLD
    Take off the window rubber and spary then install ?
    VP Exec
    May 2006
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Default Anti Rust Treatments
    Wife's 84 EFI Berlina was End Rusted yrs ago b4 we got it & she's still real smick.Dun know if anyone recalls but back in the 80's a mob came out called End Rust.They just basically sprayed under body Bitoumen inside the doors, bootlid , bonnet etc.With my VK Calais I remove the door trims once a year, I do it on both of them now & give them a good spray inside with Fish Oil.It smells like a public pi$$er for a few days after.I do it just before summer gets here so it's all dryied up for next Winter.Make sure the drain holes in the doors are free of debris like leaves & twigs & try not to park under Bottle Brush trees, mongrel things..I used old Engine Oil in the doors, tailgate & Bonnet of our old XC Wagon we had for 13yrs & that was rust free.Fish Oil $3 a can.Works for me.My Calais neva gets driven in the rain as I cun be stuffed cleaning all the crap off the underbody afterwards because it's all painted & detailed underneath.Our cars are always garaged, have Car Covers & if I wash them I leave the doors open afterwards for 20 mins to let the water out, remove the Interior light bulb 1st.Sun is a killer too just aswell as Birdsh*t.....
  15. #15
    VT Berlina & mazda 2 DE
    Jul 2006
    the electronic rust devices are the shit. I started using them when I saw a rodeo work ute, if anyone knows the std steel trays they love surface rust. Same with the steel sunrasia wheels.
    This thing was chipped all over, bare steel and NOT A DOT OF SURFACE RUST!
    I had a vitara a few years old, threw one on. Plenty of beach, no rust
    a friend had an old telstar, had a rust bubble on the rear window, fitted the device, and the rust didnt get bigger over the years she had the car.
  16. #16
    Jun 2006
    You can lift the edge of the rubber.
    Well you can on mine.
  1. beat this
    By Garth in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-09-2006, 06:59 PM
  2. Can the VN beat the VE ?!?!
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2006, 10:01 PM
  3. make a V6 beat a V8
    By SexGod in forum V6 Development And Modification
    Last Post: 08-03-2006, 10:10 PM
  4. wat will beat eb tickford
    By vsclarion4u in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2006, 07:02 PM
  5. I Beat Hsv Senators.
    By freckly in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-11-2004, 01:41 AM
