Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Post your underhood "battery" pics
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Post your underhood "battery" pics
    Alright. Here is a different one. Post your battery pics showing the cabling etc... Who has the cleanest looking battery? The best looking terminals? The best looking wiring?
    Seeing that I love good wiring connections so much, I thought I'd see.
    Here is a pretty useless pic of mine. Hard to see. My camera broke and I am getting a new one next week so I will need to wait until I get it to take a closer pic.
    If anyone can guess what is wrong with my battery in the picture below, you would be pretty smart.
    Go on! Post your VB-VK battery pics!
    VH V8
    Sep 2005
    on mine the battery posts are on the opposite sides, ie, the positive is on the right..... or is that "whats wrong" with yours!
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Well here is my battery pic, complete with 1g cabling, duel pole isolator switch, gold plated battery terminals the positive just happened to have a voltage guage on it.
    I fabricated up the mounts to snuggly fit my new optima yellow top. The 750cca turns the 5L over beautifully.
    cheers
    Scott
    Attached Thumbnails Attached Thumbnails Post your underhood "battery" pics-smimgp5545.jpg
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by bigg_vin
    Hahaha. Got it in the first reply. Yeah I made a mistake and bought a 'Ford' battery.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Thumbs up
    Quote Originally Posted by vkberlina
    cheers
    Scott
    Ok that's it! You are banned from paticipating in any future "post your..." threads.
    Nah it looks umm... gold! Pretty damn clean. Good job.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by Slim
    Lol I long overkill and over engineering, it just so happens the battery install is only 2 weeks old, I ran out of room in the engine bay for the battery so it ended up in the boot. I didnt plan on using gold connectors, its just the only ones I could fit my cable into properly without using lugs & fitted the battery terminals the optima seems ot have a bit smaller positive terminal than most.
    Spike79's Avatar
    Spike79 is offline Just Confused!
    VZ Adventra LX6, VP Berlina LX, Citroen C3
    Bubble Shooter Champion! X-Pipes Champion! Alu`s Revenge Champion!
    Feb 2006
    Brisbane N/W Ferny Hills
    Its not an underhood pic, but this is whats left of my battery after i stuffed my VK under the side of a 4WD.
    Its a new battery too, still under warranty. Maybe i could take it back to the shop.
    Attached Thumbnails Attached Thumbnails Post your underhood "battery" pics-image-284b-.jpg
    Mike's VP Berlina LX... Click Here
    Mike's VZ Adventra LX6... Click Here
    Mike's VP - Most Stock Award - March 07, October 07, April 08
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Lmao spike wtf happened there? Did u try and make it fit lmao !!
    I'll post mine tonight
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VK berlina sedan 202
    Jun 2006
    Hey Scott,
    I have pretty much the same terminals.
    They are Jaycar terminals.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by Spike79
    Just curious. Does it still hold it's charge and can you charge it, or is it cactus? If it does, then you could use it The warranty joint will tell you to piss off.
    Spike79's Avatar
    Feb 2006
    Nah, its split at the bottom so all the electrolyte has leaked out of it. It didn't hold its charge for long after that.
    I wasn't serious about taking it back either. I'd like to see their faces if i did take it back. "it was like this when i bought it"
    VH V8
    Sep 2005
    just wondering vkberlina, is it ok to put such a bigger battey in the car? mine only has a 350cca or so battery instaled at the moment, and i wanted to put a bigger battery in for a more "clean" crank, but i was not sure if it can be done.
    is it ok to do with no complications?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    You can. I put an 11 plate in my old Sigma and realised afterwards what a whole big waste of money it was.
    V8's and more powerful 6's need an 11 plate, 6 cyl 9 plate and 4 cylinders 7 plate batteries. Don't bother wasting money unless it's necessary.
  15. #15
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Several reasons for my battery choice.
    1: The battery is in the boot & I opted for the Optima as it was a sealed type battery. The physical dimensions of the Optima are alot smaller than a conventional type battery of equivelant capacity.
    2: I was worried about voltage & current drop. going from the rear to the front, although I used good wire, good connectors etc, I wanted to make sure.
    3: There are periods where I need a long lasting battery and the Optima offered this as well.
    All in all I would have settled for around a 600CCA battery but the figures of the optima I bought was higher than what I needed, so I bought it anyway.
    I am very happy with the battery
  16. #16
    VT Commodore S2
    Dec 2005
    Wollongong
  17. #17
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    1: The battery is in the boot & I opted for the Optima..........
    How much did the battery cost and how long should it last?
    The average battery lasts between 3 & 4 years I suppose. Just wondering if it would be worth paying all the extra $.
  18. #18
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Here's a better pic of mine. Better than average for older barges. Nice propane torch soldered lugs with black heatshrink over them. Nice and tidy.
  19. #19
    VH V8
    Sep 2005
  20. #20
    Mar 2004
    I always put the largest battery that I can fit/afford in my cars. My reason for doing this is that the cars are usually automatics that |I cannot push start in an emergency. I live in the country where we get severe frosts down to -4 which is hard on batteries (I hate being stuck). It has paid off for me in that I usually get about 7 to 8 years out my batteries, for usually only $20 to $40 dollars more than a standard battery.
  21. #21
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Hi craig,
    Um I know a guy with a similar optima battery that has been going strong for 5 years now, so im expecting a while.
    Price wise, mine was trade so I cant say the price but RRP is around $350 for mine.
    cheers
    Scott
  22. #22
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    where did you run the cables when you moved the battery to the boot?
    Body by Holden, Soul by Brock
    the Legend will live forever
  23. #23
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    My Mum bought her Lancer in 2002. It's still the original battery 4 1/2 years later. I thought that was not bad. What is it with factory parts? They seem to last longer.
  24. #24
    VY Calais, WHII Statesman V8, VC L 202
    Feb 2004
    SE Melbourne
    My old man got 10 years out of the factory battery in his Lite-Ace, only pulled it out because he was thinking it must be ready to start having problems (still kept it as a spare though!!). On the flipside of the coin, when I bought my WH it was 3 years old with original battery - car would struggle to turn over when I test-drove it. Condition of sale specified by me was a new battery as well as a few other items (CD stacker, suspension bushes). On a positive note the Exide K-Mart special in my VC is 6 years old, needs charging every few months now but that's a pretty good life-span.
  25. #25
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Yeah I've found that batteries need an extra seperate charge every now and then. The thing with batteries is that they never get to full capacity.
    I am seriously thinking about buying the Jaycar battery zapper kit. I am really thinking it could be a useful item. Although I might not get my money worth out of it, my cousin who is a farmer has 20+ batteries on the farm which he would benefit from it enormously.
    Check it out:
    http://www.jaycar.com.au/productView...Max=&SUBCATID=
  1. Replies: 59
    Last Post: 04-10-2008, 05:09 PM
  2. post your underhood pics here (202)
    By Stevie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-10-2007, 01:56 PM
  3. Post your underhood 253 & 308 pics
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-06-2006, 04:38 PM
  4. Post your pics of 6"X9" install on parcel shelf
    By debono55 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2005, 03:05 PM
