Results 1 to 6 of 6
Thread: 2.85 head
    VH wagon
    Aug 2005
    Default 2.85 head
    Hi every one I want to know if I can put a 2.85L head on to a 3.3L blue motor. And how can you tell the differince between them.
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    if its a blue head then yeh if its not then you need to modify some of the water jackets and oil galleries.....
    VK wagon
    Aug 2006
    NZ
    any reason for the head job? I'd go yella terra if you're going to spend that much mucking around...
    VH wagon
    Aug 2005
    Thanks for that. Its a blue head. The one I have now has got a crack in it and I need to replace it. The car is on LPG would that have cracked the head. I have been given a head off a 2.85L and was going to put it on my motor. The car is just a to get me from work and back home. I think a yellow tera head would be worth more than the car.
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    The 173 head will raise the compression a fair bit because of the different combustion chamber shape. You should get away with it running on gas but on petrol it will ping a bit.
    VE SII Sv6 Manual
    Aug 2004
    You'll also need to block of the air injection ports over the exhaust if it's from a VH.
    As the VH 2.85's (173) had the air injection the same as used on the VK carbie 6's.
  1. Cracked head? blown head gasket???
    By VL_5SPEED in forum General
    Last Post: 09-01-2010, 10:41 AM
  2. 186 head on a 202? ( red )
    By V3N0M in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-06-2006, 06:22 PM
  3. Blown head gasket or cracked head
    By ucwepn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-06-2006, 07:52 PM
  4. new key + key head
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 11:01 PM
  5. Head job
    By SNY.3LT in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2005, 12:27 PM
