hey i am in the progress of doing up my first car whicj is a vh and was wondering wat i should do with the motor side of things.
At the moment i have just a 202 blue motor but i wont a bit of grunt in it i was just wondering wat i could do to do this but not spend a whole lot.
any help would be apprecated
James
get a vk efi motor bit more grunt not overly expensive
where would i look? just wreakers or internet?
and how much just a rought price.
thanks james![]()
wreckers would be the best place or you could try trading post
this motor should set you back $300+ you do need the computer and loom aswell
maybe go 253 or 308 they cant be much more than an vk efi 202 cos u don't have to pay 4 computer.
We got rep back, yaaay!
you can tweak up a blue 6 to go just as hard as the efi 6's. For some bang for your bucks, throw on a nice flowing head, mild cam, weber or holley, set of extractors and decent ignition system, then you'll sure have a different power output...
No wah to that!
Never late with ROB308...
i had a blue 202. i put a holley, extractors and exhaust, mild cam and just looked after it, like, better leads, better plugs, better CAI, just the little things, and she went much harder than stock.....
awsom i have a holley to go on it and a set of extracters but dont know how good they are. where can i look on them to see the brand becouse they are pretty dirty?
and also any reconmendations of the head i should get?
thanks james
some extractors dont have any plates or markings to show their brand, usually the cheap ones... but a common spot is bout half way along the first pipe...
As for the head, yella terra are the most popular, if they do a 12 port, but any head reco place would be able to port and shave it for you, then get a nice set of valves and springs and you should be fine... all this can be done to your current head, but a donor head is normally the way to go so the car is off the road for less time...
No wah to that!
thanks for that you wouldnt happen to know a rough price would you?
thanks james
Most blues and blacks are a high compression engines the heads are equipped enough to handle a cam and holley 350's a perfect for a little more power with reasonable economy, match porting the head and a 2bl manifold together provides wicked flow since you have the exaust side of it. match porting is easy email me @ jismperf_00@hotmail.com i can go into more detail with you, I love holden sixes they are cheap to build and are so much fun rev nice and shit on fords. A cam will set u back anywhere from $150 - $300, I bought a stage 2 4 $175. and a stage 4 4 $185 and picked up a stage 9 of a m8 for free lots of parts r available especially from wreckers, keep looking bro, lots of cheap options, regards 186,9er
you have to send you blue or black heads to yella terra i hear, you can always take a head of a blue 2.8 lt
you can also get iridium plugs and 10 mm leads m8. its $80. 4 plugs, $49. 4 leads
if your trying to keep costs down, try a cam, 2barrel holley, good air cleaner, extractors.
Ebay will save you a fortune, and get the lot under a grand!
Allow acouple of bucks for a good allround service/tune after the works done !
DO NOT remove the snorkel on the aircleaner, use it as a base for a cold air pipe, running it down to the passager side, away from the radiator.
EFI ( VK motor ), would be great, but if you want it to be legal, there is alot of other little bits and pieces that need to be upgraded, plus mods to the fuel system.
Good Luck either way !![]()
thanks that's alot of help now i can have a look around and price some things.
if there is any other info that will help me please jost post it in.
thanks james![]()
does any one know of a online store that i can find any of the items?
that are listed in the posts above.
thanks james
