Results 1 to 5 of 5
Thread: blue smoke
    VH wagon
    Aug 2005
    Default blue smoke
    Hi every one. I have just put a head on my blue motor 3.3L. And it is blowing blue smoke when I start up. It does not blow out blue smoke when it is ideling or driving along. I just want to know if its the head or the rings. It was a second hand head i got for free. The old head was cracked and needed to be replaced. Would the water geting in from the cracked head have covered up the blowing blue smoke.
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
    VH V8
    Sep 2005
    from my experince, when blue smoke is seen only on start up, it is an indication that the valve stem seals are leaking......
    cos the oil sits on them when car is off, and leaks through slowly, you wont notice the blue smoke whilst driving cos its not much oil getting through the seals.....
    i think
    Have a good one
    .............Vincent.............
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    It could be a combination of one of or a few of, worn valve guides, perished/buggered stem seals.
    If the had has had a freshen up the valve stem seas may have been damaged at the time of fitting the valve springs, collets & retainers.
    cheers
    Scott
    VS Acclaim, VX Exec
    May 2006
    ACT
    Default Give it time??
    Quote Originally Posted by vkberlina
    cheers
    Scott
    With a newly assembled engine it sometimes takes time for the rings to form a good seal and generally to build up some carbon sealing etc....are you sure there is a problem???
  1. vz sv6 blue smoke on start up
    By kiwi nz in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-01-2012, 11:34 AM
  2. blue grey smoke on starting
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-01-2007, 12:07 PM
  3. help.. slight blue smoke from 5L ..
    By jim898 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2006, 06:02 AM
