hi i have a vh commodore straight six 5speed factory manual
and i noticed my cigerete lighter is not connected and the plug is no where to be found!?!?!?!
is it possable to make your own and wire it up to the batter or sumthing?
just grab one from a wreckers and install that - should only be a couple of bucksOriginally Posted by Tashki
ok ill try
but where would i connect it to?
usually there's one earth wire and one constant power and if it has a light it goes to accessories power. use the wires from your stereo if its easier to get to for all of em. black wire earth ( could connect/wire to the same earth wire as stereo if you can get to it ), red wire to constant power ( same deal, use the stereo's constant power, generally yellow ) and for the light the same again, connect/wire to stereos acc wire, usually red.hope that helps
yeah... good point!! forgot that one!!![]()
ok thx ill try it bro
Ar to hell with it, go getta Bic..least ya can light...????Originally Posted by Tashki
Maybe the OP wants to charge his/her phone?
it is so i can charge my phone and my interia neons i want to get.
Its an easy job mate well doing it this way is, its not that hard at all.
-----Red wire----> Fuse < ------- Red wire ----->12v Source
-------->Negative --- Will all know this one---->Earth Source
If ya wanna run them on switches with a diff wiring setup mate "without the cig needed" just PM me and ill give u the tips!![]()
a lot of the time the cigarette wires were snipped for acc feed for the new sterio...they will probably be around that area
