Hey all,
thinking of getting a stally for my s/le
i got a 5ltr going through the auto and into an lsd, just wondering whats size is best for driverbility and a bitta fun :P any help appreciated!
thanks
oh, and what is the average price on a stally, im also getting a stage 2 shift kit soon, if that helps at all
Is your car worth adding one? Has the motor had any performance modifications?
Speak to Autoflite about what you want http://www.dominatorconverter.com.au/default.htm
You'd be looking at hundreds. As for driveability, you'll be looking at spinning the rear wheels in the wet at every intersection. I wouldn't go higher than 2000-2500 rpm unless you know what you are doing.
2500rpm i find good on the street, i'm running a TCE in a trimatic. unless your going to put a cam in it, leave it standard, they both need to be considered at the same time.
Ya rite there Cane_it the cam is a good thing to work off wif a stall.
My old VK had a 3500 stall and that was fun
Slim can ya tell me why ya will be spinning the wheels at every intesection in the wet ?
Because you need a certain rpm until your torque converter kicks in.Originally Posted by Clutchy
Umm nope ya can just take off normal unless ya had ya foot on the brake then thats a different story.Originally Posted by Slim
hey how does that actually stally work. dnt u jus hold the break n gradually gain more n more rpm n let it go ??? :S
Cheers, Robbie
A high stall converter needs a certain rpm before the transmission engages.
Your normal Trimatic Torque Converters are rated at 1900RPM.I'd strengthen up yor trans 1st.Sum new Corvette Servo Pistons, Springs & clutch plate wouldn't go astray to begin with...
Tony 308vkcalais:
All ya stall will do the rev rating of it say being 3500 like mine was it wasent locked untill ya hit thoes revs in ya car and ya could hold it on the line with ya brakes up till thoes revs if ya wanted to but ya can take off normal and at low revs.
how muchwold a high stall converter cost? without labour?
Cheers, Robbie
to fit a trimatic![]()
Cheers, Robbie
I think they are a few hundred. At a rough guess $400-$600. Putting one on a 202 wouldn't be worth it unless it was a drag car. They are generally put on cars that have had performance enhancements done to peoples V8's. Labour is easy. AFAIK, taking out your gearbox and replacing the torque converter is all it is.
I met a guy once that wouldn't pull out a gearbox for less than $300, so I did it myself.![]()
dominator stall convertors are 600 exchange and more if you want a cusom 1 to suit your needs
mine was $600 for a 2800 stall with lockup clutch from all torque converters in adelaide so id imagine it would be cheaper for a trimatic with no lock up clutch cos thats the expensive bit
Cheers for the prices. I figured they wern't cheap.![]()
around $600-$700, you need t make sure the stally is chockers with transfluid before you put it onto teh trans, it will slide nicely onto the imput shaft and you will have to feel for the engagement of teh stator inside the stally.
for 202s make sure that the crank has the locating spigot in the back of the crank the little knob in the centre of the converter locates onto this, without it you'll **** up teh trns in a big way as the trans as the converter wont be held truly centre onto the back of the crank.
the stally is for engines with high performance cams that shift the HP and more importantly the torque higher up the rev range, they have a bit of "slip" down low to allow the engine not to be loaded up as much in gear so it wont stall at idle, thats a crude explanation of part of their function but theres more to it, pick up a brochure from TCE or someone reputable and they generally answer all your questions.
i have an informative brochure I scanned, if anyone know how to post up images...
For the 6 pot trumatic i think if ya get the converter out of the 4 pot auto it will be good to stall upto 2 grand just not sure if its the commodore 4 pot or the torrie converter that done that little trick.
