my baby 1984 vk calais when i start her up the idle is a bit rough then she will come good till she heats up then she is all over the place idling high n low close to stall have replaced water pump plugs n leads dizzy cap n rotor, petrol filter, air filter.. does anyone have any ideas or have had similar probs b4 i send her for a diagnostic![]()
done a comp check?
ya comp is fine thnx bud![]()
could be injectors dripping or blocked
Moved your post to the VK section.....
Have ya checked for air leaks around the carby or throtle body wot ever it has?
choke maybe?
We got rep back, yaaay!
ya did it yesterday thnx is 202 efi no leaks
