Results 1 to 12 of 12
Thread: spark issues vb253
    aghatas Guest
    Default spark issues vb253
    gday, i got a new hei dizzy and procomp coil and i get no spark. i have the 11.6V at the + terminal on the coil, and the leads are all new and fine, the neg side of coil has the black wire from the dizzy, brown wire from tacho, and another wire from the lpg stuff, and the pos side has the ignition wire and the red wire from the dizzy. i don't get any spark on any lead, not even from the coil, does anyone know how i can test the coil for spark seperate from the dizzy to see if thats the problem? cheers
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    This is a simple way of testing leads, you could do the same with the coil. Place a screw driver in the leads end then place the screw driver near a metal surface, turn the key = you should see a spark "between the screwdriver & metal surface".
    ** Caution - dont lean to far forward or touch another metal surface while doing this, or you WILL GET ZAPPED!! ** = 2 ppl for this job is easier. 1 to test, 1 to turn the key.
    Another easy way to test wiring is to use a digital muiltmeter, set it to 200 - Testing wire volts, battery etc.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    vz wagon
    Aug 2006
    Wild west of Melb
    aghatas Guest
    Mate, i already tested for spark, got none. the leads are fine. i want to test the coil for spark when its not connected to the dizzy to see if its the dizzy or the coil thats not working. cheers
    aghatas Guest
    i've tried another two coils, it must be the dizzy. does any one know how to check if a hei electronic dizzy with a bosch modualator is dead? or maybe just maybe it could be that i'm not getting a good 12v from the ignition?
    VL
    Jul 2005
    SA, Mount Gambier
    VR Berlina V6
    Sep 2005
    orange
    Quote Originally Posted by tdoyle88
    cant u just run a lead from the coil to a spark plug and test it then?
    No because you need the dizzy to open and close the negative contact of the coil or it aint doing nothing!
    If I were you aghatas i'd be checking the wiring on the dizzy.
    VL
    Jul 2005
    SA, Mount Gambier
    VR Berlina V6
    Sep 2005
    orange
    The coil needs to be opened and closed. This is done via the dizzy, either points or electromagnets opening and closing the earth circuit. I hear what you are saying and I suppose it is possible to hook up a spark plug directly to the coil but you would need to open and close the earth cicuit manually by touching and releasing the negative side of the coil to the engine or body. My bad, I probably should've worded it better.
    VL
    Jul 2005
    SA, Mount Gambier
    I get what ya sayin too, i also wonder if doin it the way i suggested will bugger the coil?
    VR Berlina V6
    Sep 2005
    orange
    Nah I dont think it would,To the best of my knowlege in your coil it is simply a coil of wire between the + and - terminals, When power is passed through this coil (by earthing the - side) it creates a magnetic field that enhances the voltage (there is a formular but who cares) enough to spark at the plug and this is passed through the centre terminal. By not switching the - side the coil,it is not a complete circuit and therfore not doing a thing.
    aghatas Guest
    i took the dizzy out and connected the red wire to a 12v power supply then i found the black wire on the dizzy was 12v, i rotated the dizzy and the black wire stayed at 12v. that must be the problem, the black wire should be sparking the coil by going of and on shouldn't it?
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. vp 5.0 has no spark
    By FCCOOL in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2007, 11:57 AM
  3. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  4. My vn has no spark
    By bullit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2006, 10:57 AM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
