Results 1 to 11 of 11
Thread: Gearbox for 253/308
    VL
    Jul 2005
    SA, Mount Gambier
    Default Gearbox for 253/308
    Hey fellas, just curious is the TH350 3speed auto replaceable with the TH700 4speed? and is goin to the TH700 any benifiet? which is a better box?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    You get better top speed on a manual, great accel with an auto
    Its upto you really and want you want out of it, or if you prefer to drive manual or an auto.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VL
    Jul 2005
    SA, Mount Gambier
    im always after accel more than top speed, altho i would like to be able to acheive atleast 160-180 if i wanted to. but for me im all about accel, so unless i had the $$$ for a tiptronic i would probs stay with an auto.
    I just wanted to know if the th700 used in the vn's etc would be a good option. if they are a stroner box compared to the th350 and if they would bolt up to the back of a 308 without an adation plate, new xmember etc.
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    im pretty sure the bellhousing patterns are the same i think the bolt up ok.... the turbo 700 has 4 gears aswell. but i think its got some electronics to figure out. not sure if its any stronger though
    VL
    Jul 2005
    SA, Mount Gambier
    im not worreid bout the electronics, that easy stuff. i was just wondering bout the bellhousing and the crossmember. would i need a new tailshaft? is the box longer?
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yeah, i believe the tailshaft is a different length, and remember it has a flange fitting to the pinion of the diff... as for the bolt pattern, it will fit if you got a turbo block, you'll prob need the VN starter motor and rear x-member tho...
    No wah to that!
    Never late with ROB308...
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    Quote Originally Posted by Goon
    by the way, they are both an auto trans...
    No wah to that!
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    but... on a 3rd note, the T700 is a lot weaker than the T350, ur only advantage will be the overdrive...
    No wah to that!
    VL
    Jul 2005
    SA, Mount Gambier
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    All turbo 700's have a 4th gear, the TH700 in the VN's up is equivilent to a
    T180 used in the states, just with a 4th gear...
    No wah to that!
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    sorry, i correct myself, the trimatic is called the T180 in the US, the T700 is equiv. to a T200, not much stronger than a stock trimatic, but a lot weaker than a T350...
    No wah to that!
  1. Gearbox?
    By diego in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-09-2007, 07:16 PM
  2. New Gearbox!
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-08-2007, 12:23 AM
  3. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  4. VB gearbox into VH
    By V3N0M in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-07-2006, 09:35 PM
  5. Gearbox
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2005, 05:06 PM
