Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Hooking Tacho Up!!! Help Me!!!
    SiLeNt-SoN's Avatar
    SiLeNt-SoN is offline 2000 WH Statesman
    2000 model WH statesman
    Sep 2006
    Arrow Hooking Tacho Up!!! Help Me!!!
    Hey
    just got my tacho, was wondering how to hook it up, it is a 1984 commy executive, i nned to things like where i wire it up to? and what wires?
    any ideas and help welcome lol
    Thanks!!!
    WH STATESMAN
    1990-VN
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
    red = positive
    black = negative
    green = negitive coil
    white = parker wire
    SiLeNt-SoN's Avatar
    Sep 2006
    Hey,
    thats about what i needed to know, but were are these wires placed? in a black coil of wires under the hood? or like under the steering wheel? or in the dash somewhere?????
    and things like, red=positive, but what colour is the positive wire?
    im hopeless at this! lol
    thanks
    WH STATESMAN
    1990-VN
    May 2005
    lol just run the red wire to the positive battery terminal
    run the black wire to a bit of metal under the dash
    with the green wire run it to the coil you will see a little - mark on one of the 2 terminals
    now your parker wire is usually a dark purple or violet colour best bet would be to get a test light and try and find it under your dash if you think you found it turn the parkers on and off and if your test light goes on and off you know thats the one but best place to look for it would be in the light switch wire loom
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by ENV5
    lol I never thought of that, for mine I just ran the wire straight to the coil.....will remember next time.
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    you're better off hooking the power wire (red) to accesories, ie. cigar lighter, clock, stereo, etc... As for the light, an idea would also be cigar lighter, clock as it then the brightness of the tacho light can also be adjusted/dimmed...
    No wah to that!
    Never late with ROB308...
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    This is just a tip#
    When using the 12v accessory in the fuse box, make sure your key isnt tunred to far fwd, i've noticed with mine being 1/2mm to far fwd wont activate the 12v access.
    So if you think your connects have an outstanding stable hold, and nothing isn't happening.. just make sure your key isnt that extra bit fwd.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    SiLeNt-SoN's Avatar
    Sep 2006
    i have:
    red wire - Battery
    Black wire - earthed
    green wire - coil
    white wire - lights
    now i have hooked these up this way, but it is not working?
    any ideas welcome please!
    thanks
    WH STATESMAN
    1990-VN
    VP Exec
    May 2006
    hey mate...similar problem, same person 2 help out, good on ya ENV5
    what part isnt working? the lights or the tacho itself? or everything?
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    did you connect the green wire to the negative terminal on the coil???
    No wah to that!
    SiLeNt-SoN's Avatar
    Sep 2006
    nothin is working?
    im sure the tacho is not fualty so i cannot think of and explanation??
    thought the earth may not be trusty but it is...!
    and yes i tried to connect to positive and negitive terminal, nothin helps?
    WH STATESMAN
    1990-VN
    VP Exec
    May 2006
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    are you positive its right, im sure its a negative...
    No wah to that!
    SiLeNt-SoN's Avatar
    Sep 2006
    what do you mean?
    i have the positive red wire to the battery for main power
    and the negative green wire to the coil?
    what u mean?
    WH STATESMAN
    1990-VN
  15. #15
    VP Exec
    May 2006
    just checking that it is connected to the battery, the only other thing i could think of would be the earth, do u have a multimeter or a voltmeter? if so you could check everything 2 make sure there is power where it is supposed 2 be, so then if it still doesnt work u can blame the tacho itself and take it back
    when i wired mine up, the light didnt work at all, but i eventually got the tacho itself to work, i had the green on the positive of the coil, was told that was wrong so changed it and it worked, the light has just decided 2 work about 2 weeks ago (tacho was installed a couple of months ago) and has worked ever since
  16. #16
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yeah, if the light doesnt turn on and the needle doesnt move, it does sound like your earth... check where you have the black wire going to, if in doubt, use a test light or multi meter to see if you have ground there...
    No wah to that!
  17. #17
    SiLeNt-SoN's Avatar
    Sep 2006
    hey
    tested the tacho in another car and it worked fine, then put it in mine and no go!
    im guessing its the earth, well more hoping its the earth lol.....
    will have another go at it tomory........
    the only thing i have not really tried is the earth, so fingers crossed!
    WH STATESMAN
    1990-VN
  18. #18
    Goon's Avatar
    Feb 2006
    GC. QLD
    Do you have chrome stips around your windows? if yes .. then try an earth on one of those screws that holds them in, thats what i have mine on atm.
    If you still have no luck try a 12v in the fuse box rather then the battery.
    ps, best connection is solderniod or the butt connection things, followed by tape.
  19. #19
    VP Exec
    May 2006
    if u have a voltmeter or test light, put that across ur black and red wire coming from the car, it should light up, if not u have a problem with 1 of them
  20. #20
    HoldenMad's Avatar
    HoldenMad is offline Have spanner, can fix!
    VT Acclaim
    Sep 2005
    Elizabeth South, SA
    find an earth that u know works on another item in the car and hook up to there or close to it. If the surface is painted u won't get a good earth, so make sure u earth it somewhere that's not painted or thick metal and a good screw.
    Hope this helps.
  21. #21
    SiLeNt-SoN's Avatar
    Sep 2006
    yeah,
    YES finally, it hooked up correctly lol... i earthed it to the metal strip on the car and it worked great...!
    all looks good, thanks people..
    WH STATESMAN
    1990-VN
  22. #22
    VP Exec
    May 2006
  23. #23
    SiLeNt-SoN's Avatar
    Sep 2006
    i had it under the dash, just a metal bar thought it may of been a good place lol
    turned out i was wrong...!
    anyone got some pics of thier tachos?
    WH STATESMAN
    1990-VN
  24. #24
    VP Exec
    May 2006
  25. #25
    VN/VT
    Sep 2005
    SA
    thats a good size i reckon, were u get it from?
  1. Hooking up tranny cooler
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2009, 03:55 PM
  2. Hooking up VS caprice seat power to an VS Acclaim
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2006, 12:11 PM
  3. Hooking up Coolant Hose
    By Joerg in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-10-2006, 04:05 PM
  4. hooking neons to your interior lights
    By vnwagon91 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-11-2005, 06:57 PM
  5. hooking clutch switch up C/C
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 04-11-2005, 12:27 PM
