Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Thermo Fans
    VH V8
    Sep 2005
    Default Thermo Fans
    ok, ive been reading a bit, and going through the threads, but i cant find the answer to my question.... maybe there is no answer.....
    would a 16" thermo, in the original V8 shroud, be better than fitting the VT twin thermo fans?
    or would the EL fans be better than both those above?
    or would you say keep the clutch fan?
    this is in a VH 253.....
    cheers
    Have a good one
    .............Vincent.............
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    thermos/electric fans are always gonna be better than a mechanical/clutch fan, as long as you have the sufficient size... but as for the difference of the ford and holden thermos, i too wanna know which is the easiest to fit to my ride...
    No wah to that!
    Never late with ROB308...
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    how much mucking around to get them to fit???
    No wah to that!
    POVRTY's Avatar
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    it depends if you have auto cooling lines or not if you dont then its simple if you do it can still be done just a bit of cutting and bending
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yeah, i'm using a seperate cooler for the trans anyway... cheers for the info dude...
    No wah to that!
    POVRTY's Avatar
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    VH V8
    Sep 2005
    ok, sounds all good...
    Ill get AU ones, unless anyone has something bad to say about them....
    and if anyone out there has done it, i would love to see some pics of the finished product...
    how much cutting and bending are we talking.... and should i be able to do most of the mounting on the radiator frame rather than threw the radiator?
    will they need to be mounted upside down?
    do you reconmned running a thermostat switch such as a davis craig one.... that taps into the top radiator hose?
    cheers
    Have a good one
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    the in hose thermo switches are fairly reliable, use it to trigger the relays for your fans, but wire it up in a series circuit so you get full power to both fans... as for the temp sensor in the radiator hose, make sure it is sealed well, i had one start leaking before...
    No wah to that!
    VH
    Jun 2006
    Yeah you may find with the AU fans that they will hang out a little past the radiator letting alot of air past.
    Ford Mondeo fans are the way to go and fit alot better.
    VH V8
    Sep 2005
    would the mondeo fans be big enough though?
    no one for the VT fans?
    Have a good one
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    I would go twin VT fans if i had the cash, but im stickn a 16ich thermo on the front as a backup, activated by switch.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VH V8
    Sep 2005
    the AU fans are more expensive than the VT fans.....
    AU are 185
    VT are 150
    which ones are actually better? ie can pull more air through?
    Have a good one
    Goon's Avatar
    Feb 2006
    GC. QLD
    There's been more VT fans around for awhile rather then AU, maybe due to the issue that the AU sucked hardcore in looks, so nobody really looked into them that much as the VT !
    But you can give AU's a go if u like mate as suggested, but the more common choice is VT twins.
  15. #15
    VH V8
    Sep 2005
  16. #16
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
  17. #17
    VH V8
    Sep 2005
    thats cheap as...
    do they cool alright though?
    Have a good one
  18. #18
    VK Calais
    Feb 2006
    I recently put a 16" fan in, they bolt up way too easily. But having never done a twin setup off an AU ect I can only guess, I'd think a single 16" is easier.
  19. #19
    VH V8
    Sep 2005
    ok, sounds good...
    i guess the main thing i would like to know now is if a single 16" fan will keep the 253 cool..... or is the AU fans the best option for this..... or the VT...... i dont want to be overheating this summer!!! thats happened to me before! not fun.....
    Have a good one
  20. #20
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
  21. #21
    VH V8
    Sep 2005
    i wanted to ditch the original shroud so i could get more air flow to the air cleaner.....
    Have a good one
  22. #22
    Goon's Avatar
    Feb 2006
    GC. QLD
    I'd got twins for sure with the 253 mate
    Get teh measurements on both types VT/AU then work from there.
  23. #23
    Dan355's Avatar
    May 2006
    Quote Originally Posted by bigg_vin
    If you want a setup thats piss easy to setup, Cheaper and that will work very effeciently go the single 16". One of these will keep a 350 cool in the hottest of days. It covers your whole radiator no probs at all. Leave the shroud on otherwise the fan wont be drawing the air through the rad as effeciently. But that only applies if you are mounting the fan on the inside of your bay. Will also get the air flowing through your bay cooling any chrome ect and will feed a little more air to you cleaner. You could modify the shroud to make this more effecient.
    Also when using a thermatic switch put the temp sensor on the bottom hose not the top. This is because you want the fans to cut in when the rad isnt doing it's job of cooling the coolant.
  24. #24
    DANNY8's Avatar
    Apr 2004
    thats cheap as...
    Dunno yet, but 2 12" thermo's should definetely be ok I'd say lol. When I finish my motor and put it back in I'll make a frame up for the thermo's then put them in. Don't know wether to put them in front or behind the radiator tho...
  25. #25
    84 VK 3.3 Converted to EFI
    Nov 2005
    instead of a thermatic switch could i just run power through the ignition..so i have on when i start and off when i turn off
  1. Thermo fans into a VC
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-06-2009, 02:46 PM
  2. Thermo fans
    By 12000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2007, 03:19 PM
  3. thermo fans
    Last Post: 16-04-2007, 09:37 PM
  4. thermo fans
    By urmyho in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 10:44 AM
  5. thermo fans dont come on
    By superchargedv6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2005, 05:33 PM
