Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Manual pedals
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Manual pedals
    Hi all, which below is V8 manual pedals?
    Thanks.
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Bit hard to tell from those pics mate. Best pics would be from the side and the clutch pedal moved to show where the clucth cable sits.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Would anyone know the GMH part number for V8 pedals? If it has it written on it though.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well there is two part numbers for a V8 Clutch pedal
    92001164(with fitted bush)
    92017397(without bushes)
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    I suppose they go where the pivot point is. I'll have to look further into it mate
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I got my pedals today. The only numbers on it is SE84.
    The ebay seller said it came off a VK V8. I need to make sure they are definately off that.
    Can you tell from the pics if anything is missing?
    Thanks.
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Looking at this pic It looks like a 6 cylinder clutch pedal. The "hook" part needs t be a bit longer. I will try to get a pic out of my VB-VK parts manual.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Bloody great. The seller not only delays posting it for a month but the damn pedals are out of a 6?
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Ok as promised, a diagram for a 6 cylinder Commodore clutch pedal. Please take note of the "hook" area.
    And this is the V8 Clutch pedal for a VB-VK Commodore.
    I still say Slim, the one in the pics is a 6 cylinder clutch pedal.
    Oh i should also point out that Dellow Automotive actually make proper VB-VK V8 Clutch/brake pedal boxes.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Ok. Thanks for that. Do I sell it off and find another one or can I use this in my VK at all? Damn I am annoyed.
    Can I ask what manual you scanned? Looks like I haven't got that one.
    Cheers,
    Craig
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    You can use a 6 cylinder one, but it will feel a bit funny in pedal pressure. Its up to you if you want to sell it.
    The manual i took the pics of is the Holden parts catalogue VB-VK. Its very thick!.
    BnSuter's Avatar
    BnSuter is offline Meow Meow F**kin' wow
    VS S2 S pack ute
    Feb 2006
    Victoria, I'm from the country an I like it that way!
    Hey SL/ENUT you sound like you know abit about these Vk manual set ups. just wondering if you could help me out i've got a VK calais with a HDT kit on it. It's all origenal i'm the second owner, preveously owned by another member of the family, with only a touch over 180,000k's on the clock. To the point just this last week I have been thinking of changing it to a manual. I can get my hands on a VK berlina with the same efi 202 motor. But today i was speaking to someone and they told me to be careful that the two bodys aren't diffrent meaning that my VK calais might have a bigger hul cut out to fit the auto is this true.....
    Thanks for you help
    My an My 904 Kickin' On Flat to The Floor
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    I know the VL trans tunnel is different, but the VKs use the same floor plan as the VB-VK. The only real difference in the VK Calais and VK Berlina is the electrics, thats it.
    So no its not true, they both use the same trans hul
  15. #15
    BnSuter's Avatar
    VS S2 S pack ute
    Feb 2006
    What electrics are diffrent, I know i will have to bridge the inhibrator switch. Is the speedo cable driven or electric. Sorry i'm a diesel mechanic by trade and don't realy get turned on by working on cars.
  16. #16
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    The speedo cables are both driven. AFAIK, the only electric difference is the dash in the Calais is electronic and the cruise control output on the unit has a transducer that converters the mechanical signal of it spinning into an electronic signal for the dash speedo, instead of using a cable to the dash for the speedo.
  17. #17
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by SL/ENUT View Post
    Will the pedals I have mount up without problem over the ones I currently have in my auto? Are the bolt holes the same or will I need to make holes? When you say funny, are you talking about the clutch or the brake pedal? What is the actual difference between the 6 and V8 apart from the extra length in where the clutch cable mounts?
    Cheers.
  18. #18
    BnSuter's Avatar
    VS S2 S pack ute
    Feb 2006
    This is a loop hole i am faceing i've only read tonight about the calais having cruise control and electric dash. I brought it off my auntie and she was the first owner of it, theres no books in the car but it has calais badges. I'll look into how to determine what it is. Its got the dash that still reads in vaccum pressure on them ugly square gauges
  19. #19
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by Slim View Post
    Cheers.
    Yep the bolts are the same, so they will bolt in, no worries.
    What i mean about funny pedal preassue is the clutch pedal. It will feel like the clutch is a very heavy. I think the clutch spring is a little more tighter something to do with the spring back action.
  20. #20
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Thanks.
    Would you happen to have a diagram of where the pedal assembly meets the brake booster and clutch?
  21. #21
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
  22. #22
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    EDIT waht sort of diagram do you want?. Got one here of the brake pedal support, the bit that holds the brake and clutch pedals and bolts into the firewall.
  23. #23
    BnSuter's Avatar
    VS S2 S pack ute
    Feb 2006
    all these troubles SL/ENUT is having getting the pedal set up right seams worrying for me to get mine converted, Is the break boosters diffrent from manual to auto vehicles. The manual i've brought is in a complete berlina so i'm hoping not to face these difficalties. I'm not desperate for the manual just like the idea of having a clutch when you lack power.
  24. #24
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    There isn't any difference between manual and auto brake boosters, ther is however a difference if its rear disc or drum. The brake boosters are all in the same spot
  25. #25
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Sweet, so the pedals I have will mount up whether I have a VK Calais with rear discs or a VB commo with drums?
    Thanks mate.
  1. VB-VK 6 cylinder manual pedals
    By craigvk in forum Parts And Other Items For Sale
    Last Post: 06-11-2006, 09:07 AM
  2. SS Pedals on a SV6
    By SV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2006, 05:04 AM
  3. OMG Pedals
    By MavVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 06:02 PM
  4. pedals
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2005, 04:46 PM
  5. pedals
    By andyvys2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-05-2005, 10:47 PM
