Results 1 to 11 of 11
Thread: Jack points.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Jack points.
    Hey All
    Just need some tips on jack points on my VC, are the areas usally the same as the rest from VB - VK ? i know places for single jack use but thats for 1min or less.
    I'm lookin at using 4 jacks and 2 car stands to replace 2 jacks, as i need the ride up on all 4's for 20.30mins less or 1 hr max. What would be the best places? would it be best to use the stands are the front or rear? "they all support over 1 ton"
    I plan to repair my exhaust end and service my gearbox.
    Thanks
    PS> Gearbox service question : Torque wrench can be brought from bunnings?
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    mate, you're a lot better off with 4 stands and 2 jacks instead of the other way rond, a car supported on 4 jacks is very unsafe...
    as for the jacking points, jack it up by your front x-member, then place your stands at the strengthened part of the chassis just in front of your front door, it goes from your sill to the chassis rail...
    as for the rear, jack it up from the diff, then place your stands under your 2 points (look like a U) just in front of your rear wheels...
    This should hold it all nice and stable for you... they are the same points you'd lift it up with with a 2 post hoist...
    No wah to that!
    Never late with ROB308...
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    and yes, a torque wrench ca be purchased from almost any hardware of auto shop, just remember, dont go cheap, the cheaper they are, the less accurate and shorter life they have...
    No wah to that!
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    As the above says ^.
    I am going to be getting a torque wrench soon, and the only one I will buy is the Sidchrome 1/2 inch ratchet with nm scale under clear plastic on the handle and it moves freely and is a brilliant one. They are about $265. My cousin has one and it's the best.
    http://www.justtools.com.au/prod2677.htm
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yeah, sidchrome, snap-on or blue point would probably be your best options, but like i said, you're better off spending a couple of 100 dollars than spending 50 bucks and getting the wrong tension on an important bolt...
    No wah to that!
    Goon's Avatar
    Feb 2006
    GC. QLD
    Thanks for the info guys
    If i do go that way ill have tyers for extra safety + more jacks
    Or i just might dig a trench
    Anyhow cheers
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by atrail308 View Post
    dig a pit...
    My cousin did that years ago in his farm workshop. Spent an hour after school every day when he was younger and finally did it. Reinforced concrete with steel mesh and it was done. If I had my own garage, I'd do it!
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    i'd love one, but i cant see my self to be motivated enough to dig such a big hole... i'd probably fall in it anyway... lol...
    No wah to that!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    If you do a lot of work on cars, you know how much of a pain in the back it is crawling under the car with about a foot of space.
    Having a pit (or access to one) makes working on cars a breeze!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    All your mates would want to use your pit too if you had one.
  1. Rear Jack points on Vp vacationer.....
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2007, 08:11 PM
  2. Vp Vacationer Jack Points Rear???
    Last Post: 18-10-2007, 08:47 PM
  3. how to jack up a VL
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-08-2007, 10:46 PM
  4. Jack replacement
    By bhodder in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-12-2005, 05:51 PM
  5. Trolley Jack
    By TigerVX in forum General
    Last Post: 05-12-2005, 03:46 PM
