Results 1 to 6 of 6
Thread: Buying a VB Commodore
    Stuie Guest
    Default Buying a VB Commodore
    Hey Folks
    Looking at buying a VB for the wife and baby to run to the shops etc in and saw one today quickly should have looked longer but was in a hurry!
    Ok what do i specifically look for in the way of faults or potential problems with a VB? How can i be sure its not gone from a six to a 8? Does it matter or the suspension etc the same and how do i tell?
    SL model
    Its had alot done to it lately .......
    Reco 4.2l long motor
    New heavy duty radiator
    New front disc rotors and pads
    New front struts
    New fuel pump
    Recoed carby
    Its says also regulary serviced and at the $1800 mark seems a good buy at present withpout having done a major inspection.
    Any input appreciated.
    THANKS For the help.Im really into American stuff but this looked like a little gem.
    STUART
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Post up the details of the build plate, then i can work it out if its a SL and if its a factory V8.
    The build plate is a rectangler plate with Model, Body Number.
    For faults well look here http://au.geocities.com/commodoretech/vbfaults.html, thats most of the fualts in the VBs
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    The VB came with a 4.2L (253) V8 with a 3 speed Trimatic (M40) and a 2.78:1 diff & a 3.08 as a performance option or a Aussie 4 speed (M20) and a 3.08:1 diff.
    The 4.2L engine should have an engine number prefix starting with VR the Product option for the engine on the complience plate should be L36, M20 for a 4 speed manual, M40 for a 3 speed auto. GU4 for a 3.08 diff & GU7 for the 2.78.
    Look for the VIN plate on the car also, it will read :
    Luxury, K - commodore, L - SL, X- SL/E
    19 or 69 for Sedan, or 35 for wagon
    5th character is the engine code
    6th character year of manufacture H-1978, J- 1979
    7th&8th characters builod plant
    H1-H4 = Brisbane
    H5-H9 = Sydney
    J1-J9 = Melbourne
    L1-L9 = Adelade
    The last character should be a B as in the model code VB
    I have more VIN info on my Site.
    If its got a Turbo 400 it will have an ID plate on the RH side of the transmission with a serial number like 79 - EK - 1111
    79 being the year, EK is the 4.2 & 5L code & 1111 is a sample serial number
    cheers
    Scott
    Shanoqueeb Guest
    1800 is a pretty good price considering how much it costs to put a new engine in and all the repairs
    2007 VZ ACCLAIM WAGON
    Feb 2005
    St Clair
    Check in boot under the rubber mat...Boots leak...water stays trapped under mat..hence no boot floor..Rusted Out
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Check out the rust mate, sometimes it can be bad, but sometimes it can just be surface rust, which is easy fixed if you know how
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
  1. buying a Vt Commodore
    By vsmadman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2006, 05:43 PM
  2. Advice Buying Commodore SS
    By Sarkis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2006, 01:34 PM
  3. Buying a 2003/4 S VY Supercharged Commodore
    By Deee in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-02-2006, 12:16 AM
  4. Commodore V8 - buying advice wanted
    By NZv8fan in forum General
    Last Post: 03-02-2006, 10:49 AM
  5. Problems To Look For When Buying A VP Commodore
    By Dr_Hoon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2004, 08:41 PM
