Any One After A Cold Air Tray For Vk Got To Link To Have Alook
thats not real good
anyone got some instructions on fitting one of these, i am guess there is very little to it but still.......
cheers
you need to cut the fan shroud a bit, cut out the top section in the middle but leave a little on either side sitting up proud from the radiator, this will help locate it, the carby end is atached with some rivets etc to the underside of the bottom part of the aircleaner assembly, follow your nose, they rent hard to install but like anything measure twice before doing anything permanent.
ahhh no! you dont need to cut the shroud at all, the tray sits over the top of it all and you dont pop rivet anything to the carbie area at all, either the air cleaner or the tray. the tray is held in place at the front with two "L" shaped metal tabs that screw into the radiator top and at the carbie by the air cleaner assy. you locate it by the tabs at the front and screw it in place, put the bottom section of the air cleaner on top of the tray, then air cleaner, then tighten the air cleaner top down. you dont cut anything or pop rivet the tray to the air cleaner housing!!! how do i know, i have a genuine brock commodore with a genuine HDT air tray
