i took my old vh out for a run today (the one i am goin to rebuild) and for no reason i came up to a set of lights and when i stoped and put the clutch in it jus died and it done it nearly everytime i stoped could it have something to do with the fuel pump???
Homer: "for once in my life someone is calling me sir without (your making a scene)"
Was it ok when the motor was at operating temperature?
A simple solution could be to just turn the idle up, but that won't be solving the problem (not unless the problem is ur idle turned down to much).
I don't think it would be ya fuel pump, coz if it pumps enuf to keep up when ur driving then I'd say it should be good enuf to keep it idling. Maybe the timing is out a bit? Does it misfire at all? Maybe change ur plugs and leads possibly?
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
It done it a fair bit before and after it got to runnning temp and it didnt missfire or anything it jus died like you turned the key off
Get a can of WD40/Inox/RP7 and pull all your spark plug leads off and spray some lube in them. Also pull your distributor leads off and spray some in each plug too. Takke the cap off and spray some inside. Is your car on gas? What was the last thing you remember doing to your car before this play-ups started happening? Is your ignition coil wiring shorting with any of the chassis?
It sounds a bit strange just going dead. Usually it would cough a bit and then die, but with gas it just dies, that's why I asked if you have LPG.
naa its not on gas and the only other thing i have done to it was put on a dif carby on about a year ago and it did not play up or anything then it jus started stalling for no reason it would not hickup or anything it would jus die
Sounds like a possible vacuum leak. Did you replace the base gasket when you changed the carb?
yea slim when i put the new one on i brought a gasket kit for it and a month after that me mate put a timing gun on it and he said everything seems alright
Likely is. Water level won't make a difference. If your timing is out or even way out, it shouldn't stall. It would just idle like a barge.
Does it only stall when the car has warmed up? LIke does it stall for the first 2-3 kilometres?
It was just an idea as if u lose water she heats up causing her to stall
Do the problems occur on 2nd gear if u have a manual? does the battery light flicer on and off when u slow down ta the traffic lights?
Then the above might work for you.
Could also be related to anti diseling...
when i turned it on this morn and left it to idle a bit the idle got higher and then i tapped the throttle and then it stalled and when i was drivin it it stalled when i stoped and put me clutch in like it did not play up at all it jus died
