Results 1 to 18 of 18
Thread: how to remove
    84 VK 3.3 Converted to EFI
    Nov 2005
    Default how to remove
    hey i stripping black 3.3 block i was wondering if some1 could tell me how to remove this pully cheers.....
    Mods-Conversion
    4 Speed Manual conversion,
    VB Dash,
    EFI conversion,
    Straight Gas,
    VH seats and door trims,
    5" tacho,
    POD Filter,
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Hard to figure out what is in the photo, but you'll probably need access to a bearing puller. Wasn't there a nut on the end of it? What pulley is it?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Nov 2005
    its what the big bottom pully bolts onto....
    Mods-Conversion
    VB Dash,
    EFI conversion,
    Straight Gas,
    5" tacho,
    POD Filter,
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    You dont have a greg's book ?
    Then buy one!
    There chip as chips over ebay, i brought mine for 15 dollars!! almost new !
    Sorry mate ive seen u ask a few question which i wish i hada book to give to you, it would make it so much easier
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by figjamidhVK8t4 View Post
    It looks like a timing cover but looks weird. Get a bearing puller.
    And it's PULLEY not PULLY.
    Nov 2005
    I HAVE 2 gregs and the black calais 1 i must be blind as a bat i spent ages seaching through both so i geuss the search is on again...
    Mods-Conversion
    VB Dash,
    EFI conversion,
    Straight Gas,
    5" tacho,
    POD Filter,
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Ok its the harmonic balencer your talking about, you need a harmonic balencer pully to get it off the end of the crank shaft.
    They are a friction fit, spray a pit of inox in the centre the day before you try pulling it off it will help it come off more easy.
    cheers
    Scott
    the lightning
    Jun 2005
    under the Southern Cross
    get a gear/balancer puller, about $15 from supercheap, you place the three bolts in the three threaded holes in the balancer pulley and the threaded centre bolt that locates into the centre of the pulley needs to be tightened to pull the balancer off...
    if you had trouble workin that out, wait till you get to the two philips head screws that hold the cam retaining plate in, you'll need an impact driver to remove them, if you snap em then it'll be fun and games with a bolt extractor. I recommend getting a can of liquid spanner and give them a squirt every 4-5 hours and another squirt before leaving it overnight before any attempt at removing them.
    as for the rest of it, just follow your nose, oil pump + dizzy have to come off and lifters removed before you can slide the cam out... good luck, theyre a good motor to learn on....
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    I can't believe it took 8 posts before someone was even able to identify it as a harmonic balancer!
    This is a worry :|
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    Quote Originally Posted by synoptica View Post
    This is a worry :|
    SAD REALLY...
    No wah to that!
    Never late with ROB308...
    Nov 2005
    i had an idea it was but i just thought it i'll look better if i didnt know rather then get it wrong
    Mods-Conversion
    VB Dash,
    EFI conversion,
    Straight Gas,
    5" tacho,
    POD Filter,
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    How many bush mechanics does it take to identify a 3.3 harmonic balancer....
    Body by Holden, Soul by Brock
    the Legend will live forever
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Neither can I Just a tip guys when you install a harmonic balencer on a 202 best to always use a new one dont reuse a second hand one.
    Also I usually bash them onto the crank using a brass hammer it saves damaging the balencer & crank.
    Also DO NOT WELD it on you will root the crank.
    cheers
    Scott
  15. #15
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    This is a worry :|
    Yeah true. I see what you mean. I must be smoking or drinking too much. I see again now that it's obviously a balancer, but without the bottom pulley! Strange how it doesn't have a nut on it though. My 253 & 308 balancer has a nut on it.
  16. #16
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    The 202 Balencers dont have a nut or bolt unclip their V8 counterparts. The 202 balencer is a friction fit and is a prick of a thing
    cheers
    Scott
  17. #17
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by vkberlina View Post
    cheers
    Scott
    Thanks mate
    It's no wonder I thought it was weird seeing that I only have V8 motors here. I knew it was a timing cover but I couldn't figure it out because it had no nut on the harmonic balancer.
    Maybe I wasn't smoking too much after all. Just never seen one
  18. #18
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Oh yes, sorry V8's have a bolt, not a nut on the balancer. About an inch long from memory.
  1. How to remove cam
    By ascension24 in forum V6 Development And Modification
    Last Post: 13-03-2007, 11:46 AM
  2. Help Remove My Rack!
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 08:41 AM
  3. should i remove IRS
    By fraesralj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-08-2006, 06:29 AM
  4. How to remove stripped nut
    By travb81 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-05-2006, 10:16 PM
  5. How to remove?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 12:24 PM
