Results 1 to 15 of 15
Thread: 'torque converter lockup issues'
    bAAAz is offline <۩bÂz۩>™
    VK 5.0
    Sep 2005
    Default 'torque converter lockup issues'
    hi guys just recently done a injected 8 and t700 conversion on my vk and havin issues with the lock-up converter doing all the wrong things.
    Just a stock vn 304 did all the wirings ourselves, the converter is a pro converters 2500 auto is the ussual sift kit, clutches, band, ect ect. 3.9 gears.
    First gear is sweet, no lock up, stalls to 2500ish change to second is fine too.
    once it get a halfway through second converter locks up. id say as little as 30-40kph. stays locked through 2-3 change also 3-4 change. imagine dumping the clutch in a manual while driving normals. almost bunny hopping.
    ok so converter is locked everywhere above 40ish kph no matter wat the throttle is doin (cruise-full throttle). while cruising if i back off u can feel the conveter disengage, revs cum up a bit but as soon as u give it throttle, half second later locks back up. interesting to drive at freeway speeds, doin 110 locked up doin say 2200 back right off or evan just to light throttle, converter unlocks, revs cum up then back on throttle to speed up or when u give it shit to overtake it f*ckin locks up!
    been through wiring three times all seemed sweet, added another wire that wasnt there from shifter to tell the ecu wat its doin but still no good. also replaced speedo sensor cause a wire was broken (thought that would have been a sure fix :[ )
    the trigger wire for the lockup ( grey/red i think) changes with throttle input, its getting 0.05v when on throttle, 13.5 off throttle. i thinks thats all it does. doesnt seem to change voltage at 80 like u think it would.
    gonna try a TPS see how that goes but dont think thats the problem. have been drivin round with the terminal out of the plug so it doesnt work at all HELP ME please all u gurus out there..... its drivin me crazy...
    Edit/Delete Message
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    it sounds like the wires on the solonid in the transmition are on backwards or have loose conections.
    also check the earth strap to the block it could be that...
    what was the engine and box out of?? and did you drive it before you took it out?
    was the transmition built by yourself or a n auto builder
    if it was built by a pro take it in and tell them they ****ed it up
    but most likely it wil be the wires are on backwards, but that dosnt explain why it locks up in second. they should only lock up in third an fourth.
    or maby someone left out a seal when they built the transmition and its giving the lock up fluid when its not suposed to...
    ill have a think about it and i will also ask my mate who builds proformance transmitions
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    VH SL/E 304 (injected)
    Jul 2005
    sydney
    is it a standard computer that your running there?
    the computer should not lock up the converter unless its in 4th gear and ubove a sertain speed and the gearbox fluid is ubove a sertain temp. it should also disengauge when you accelerate hevly.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Are you running the Vehicle speed sensor in the gearbox?
    There are 3 wires out of the speed sensor
    Pink with blue trace goes to the torque converter lock up solenoid & ignition
    Black with White trace - Thats your earth
    Violet with white trace would normally run to The speedo/trip computer.
    If its all connected up correctly, the violet & white wire that goes to the speedo a wire comes out of the speedo brown with yellow trace and goes to A10 on the ECU plug, might have something to do there.
    cheers
    Scott
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    after some investigation i'm 98% sure that it's in the tune
    lucky i know a guy that can fix it up for you tomorrow
    haha!
    failing that: might have to check that wiring..
    Last edited by VN_Luke; 11-10-2006 at 11:08 PM. Reason: i looooooooooooooove potato
    VP Executive R-spec
    Jan 2005
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    yeah thats what i was thinking, sounds like its off when it should be on and vice versa
    VK 5.0
    Sep 2005
    ud think so but we have been through the wiring 3 time had gmh scamatics books and diagnosis books and it all seams to look like it should
    it does seem like its workin back to front i guessed that right at the start but why not in first gear and only over 40 kph
    ohh and the car doesnt want to idle now keeps stalling when its cold i think it comes good when warm but idle is low dunno if it has anything to do with it
    VK 5.0
    Sep 2005
    Quote Originally Posted by VP_Luke View Post
    haha!
    its been doin it since we first drove it before your memcal stock tune
    VK 5.0
    Sep 2005
    thanx dude vn motor auto i bought seperatly its pre electronic (t700) built by pros the car got all new everything so never drivin before motor had been in a vk for 6 months but running no lock up its gotta be in the wiring
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Have merged both of your threads together. No need to crosspost across different sections thanks.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    i think you will find the TCC wire is shorted to ground somewhere
    this will cause very similar symptoms to your description
    Rob
    VK 5.0
    Sep 2005
    Quote Originally Posted by Doctor Bob View Post
    Rob
    the 2 wires for lockup (not black) are shorted while pluged in the auto but not when i pulled the loom out
    Doctor Bob's Avatar
    May 2004
    maybe the solenoid in the trans is crook?
    its been a long time i will look up what it supposed to measure through it
    Rob
  15. #15
    VK 5.0
    Sep 2005
    been through the diagnostics book, its says if the auto fluid get above 130 degrees or somewhere around there it lock the converter to cool it back down. 2nd 3rd 4th anything above 8% throttle which is exactly wat its doin. unpluged all the wires, swap them all around in every different combo and its either doent work at all or it does the above mentioned
    tryed everything else but cant get it to work wiring was spot on so must me this sensor
  1. 'torque converter lockup issues'
    By bAAAz in forum Electrical Wiring / Questions
    Last Post: 14-10-2006, 10:13 AM
  2. torque converter
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2006, 10:51 PM
  3. Disabling torque convertor lockup - possible?
    By Clacker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-04-2006, 11:55 PM
  4. Torque Converter
    By Indy_387 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2005, 03:52 AM
  5. Torque converter lockup
    By hophoar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2004, 09:37 AM
