Results 1 to 18 of 18
Thread: Timing & Gears. = Blue 202
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Timing & Gears. = Blue 202
    Hey All
    A question in timing, is it possible to use those plastic deg markers for timing? *the half circle* I did a tune up today and i noticed shes out by 1 deg and i dont wanna go to far fwd
    Max rpm for an auto tri box on a blue 202 ?
    Thanks
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    VK wagon
    Aug 2006
    NZ
    dunno about the timing..but (when I was younger) and had brought my 1st auto (202 + trimatic) the car maxed out at 120 kph in '2'.... then my mate told me to stick it in 'D', so clicked up the lever to push it forward and went into reverse.....scary
    Goon's Avatar
    Feb 2006
    GC. QLD
    I'm talking abut timing with the dizzy, if i was to use the deg thing.
    What was ur rpm at 120?
    VK wagon
    Aug 2006
    NZ
    yeah you can use them but I dn't know the proper degrees.. and i was red lining at 120 ... it just wouldn't go any faster
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Not sure about the degree scale plastic thing. If it looks ok and you want to use it then why not.
    I have seen some fancy harmonic balancers that have nice laser cut scales in them too.
    As for rpm range, my car goes up to about 8000 I think. Yours would be about the same. You don't want to redline it. I don't think I have gone over 4500 rpm in my car. It's unimportant.
    As for adjusting the timing, what did you do it again for? I thought you did it a while back. If it's a degree out, why don't you set it properly?
    Goon's Avatar
    Feb 2006
    GC. QLD
    I just touched the dizzy abit this time, i did it for pickup from 0 - 60 it was a bit slow, now it has improved and in the long run 80k + i save on fuel usage.
    The ignition sounds better.
    I noticed on idle in N its a a bit blow its right mark 900rpm so its a bit off.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Can you improve on kw? with timing? with advance and retard?
    LH Torana with Ecotec V6
    May 2004
    Tenambit, NSW.
    you sure can, if your engine is running retarded to what it can handle then you will loose out on power and economy.
    effectively what you are doing when you advance it is to ignite the air/fuel mixture sooner in the cycle which means it has a head start and so it starts burning as the piston is still coming up, what this means is that theres a better burn and hense more amount of energy to push the piston down with, hense better power and as a result of a better burn of the air/fuel you get better economy.
    better bang for your buck so to speak
    the other thing to remember is that if you go too far with advance you will eventually get pinging which can be bad or worse for long periods of time.
    the limit for each engine will depend on its compression ratio and the octane rating of the fuel you are using.
    for example, my blue 202 has 9.4 to 1 compression ratio, on 95 octane fuel (premium unleaded) it seems happy on +4 degrees advance, however if i put 98 octane fuel in it i am able to advance it to about +8-9 degrees, this gives a noticable increase in power and probably better economy, however you have to weigh up the price of fuel hense why i set it to +4 as the missus refuses to put 98 in it (i don't blame her)
    advancing/retarding the timing will also change the idle rpm, so if you adjust it enough you may need to change the idle stop to lower/increase idle speed as required.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Quote Originally Posted by Slim View Post
    8000rpm on a standard holden 6? I don't think so
    My 173 5spd has hit 5200rpm when I changed from 3rd back to second to slow down from going pretty qwik (it was a crap motor as well). And the wagon got to about 5200rpm just reving it in neutral. I was told they barely go over 5000rpm, so 8000rpm out of a stock 202 I think is impossible.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Ok, wrong on that point champ. I didn't know for sure because my bros VK 202 has that shitty economy guage thing.
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    LOL, 8000rpm + stock 202 = BANG!
    As for the timing, on a stock 202 they seem to like about 7-8 degrees, as long as you're running premium fuel...
    No wah to that!
    Never late with ROB308...
    Goon's Avatar
    Feb 2006
    GC. QLD
    A question about my gearbox, being an auto.. the timing works with the speed/rpm that it changes gears? so if they gears where changing at the right speed then the right timing is acheived?
    Does anybody know the gear speeds/rpm that the tribox changes at for a 202?
    I had info somewhere.. but can't seem to find it
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Goon's Avatar
    Feb 2006
    GC. QLD
    thanks mate.
  15. #15
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Goon,
    Do you know that modulator round thing stuck on the back of the Trimatic? It has a 2 inch long 1/4" black hose and then a long 1/4" pipe that travels up to your engine bay. That is what controls your gear shifting. On the 308, it connects to the back of the carb. I am sure it will be the same for 6's. The pipe must be well sealed and no leaks as I found a leak in mine once and it wouldn't go up in gear.
    The Gregs manual doesn't go into detail with the modulator, but I think the factory manuals do. If you can get hold of a VB factory and VC supplement factory manuals, then you'll have a lot more info about your whole car.
  16. #16
    HsvPlayBoy is offline Banned
    Vr Hsv 185i
    Dec 2004
  17. #17
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
  18. #18
    Goon's Avatar
    Feb 2006
    GC. QLD
    Goon,
    I know the above mate and yes its the same on 6's apart from going to the manifold instead of the carby.
    Your gregs book doesnt? mine seems to have info in testing for operations on the unit etc
    Nevermind though mate, ill sort this stuff out
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. Timing gears
    By CHANDLC in forum V6 Development And Modification
    Last Post: 14-03-2007, 08:24 AM
  3. timing gears
    By Chaddy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-01-2006, 01:11 PM
  4. straight cut timing gears
    By petroleum in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-01-2005, 12:19 AM
  5. Straight Cut Timing Gears
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2004, 10:45 AM
