Results 1 to 14 of 14
Thread: Signs of wheel alignment needed?
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Signs of wheel alignment needed?
    Hey Hey
    Another question ! Signs/symptons of wheel alignment needed?
    Thanks.
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    uneven wear on the tyres is the most visual sign for a wheel alignment.
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    uneven wear from one side of the tread footprint to the other.
    let go of the steering wheel (dont make a bloody cup of coffee either, just take your hands off the wheel a little) while driving at speed. 60kmh will do.
    and see where the car goes .. if the car drifts left or right within a couple of seconds. your out. BUT if the car ever so gradually drifts LEFT .. your fine. thats just the camber of the road and your alignment is fine..
    IF IN DOUBT GET ONE ANYWAY .. it will only help mate
    never late in a 3 0 .. uhhh ... intercooled turbo
    yes i drive an mx6 turbo ... its probably quicker than yours.
    VK wagon
    Aug 2006
    NZ
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Yes wandering over the road is a sign. Having a difficult time trying to keep it going in a straight line and having to use excess hand control on the wheel. Arms a little tired after a journey. Baldness as said previously.
    It's hard to get a decent alignment job on the old commos. Without a set of adjustable strut mount tops, it's hard to get good alignment.
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    Your old VC no doubt has worn out Steering & Suspension components.Unless you've dun a full front end rebuild or intend doing it in the near future I wouldn't bother trying for a wheel Alignment.The 1st thing they'll tell is your Ball Joints, Stab Links, Radius Rod Bushes & the Rack Ends in the P/S will be shagged.I'm redoing all her P/ Steering & Front end atm.I've dun lots of front ends b4.I have all the tools & it's has still cost her over $500.Triple that if you have it dun by a Mechanic I spoz.I'll take it out in trade...
    Tony 308vkcalais:
    Goon's Avatar
    Feb 2006
    GC. QLD
    Well doesnt sound as bad as any of these comments atm
    My guess is the shiAt house roads around my area, but thanks for the info
    matty88's Avatar
    matty88 is offline LPG Installer :p
    TEXXXY: Resprayed TX3 Non Turbo
    Aug 2005
    Doveton
    Of course, do the no hands test on a clear stretch of road with no traffic!
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by Goon View Post
    poorly maintained roads throw out wheel alignments pretty quick
    We got rep back, yaaay!
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    just like the streets of halletts...
    No wah to that!
    Never late with ROB308...
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Goon, what are the condition of your bushings? You said you replaced a set at the rear.
    I ended up virtually replacing every bush in my car except the rear upper trailing arm bushes. The rest were either totally rooted or worn out.
    Two sets of bushes I would be suspect about with a car that is quite a few years old is the radius rod ones and also the front lower control arms. I replaced both.
    The stabiliser bar link rod bushes wear out too and should be replaced to provide good & stable roll. They aren't overly important, but I replaced mine front and rear with Urethane bushes. There is 8 for the front and 8 for the back.
    Don't avoid your bushes. If you want your car in top condition, replace them if on the way out. It will make your alignment better to get right too and your car won't be bouncing all over the road or sagging.
    Goon's Avatar
    Feb 2006
    GC. QLD
    Nah bushes are all good, i just have to find a decent road atm with n traffic, it's a shame i cant drive out on the airport
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    If your bushes are fine, that's a surprise. It's either:
    Car has been well looked after and not had heavy cargo or thrashed.
    Or
    The bushes had been replaced in the last few years.
    They won't be original bushes. If replacing them, use Urethane or Nolathane bushes.
    A straight dirt road is a damn good test for alignment.
    If you haven't got any of the symtoms as said above, don't worry about it!
    JD
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by atrail308 View Post
    for sure
  1. Wheel alignment VE Omega
    By herkman in forum VE Holden Commodore (2006 - ?)
    Last Post: 30-12-2006, 10:38 AM
  2. Wheel Alignment
    By Shounak in forum General
    Last Post: 29-10-2006, 06:55 PM
  3. re:vk black efi wheel alignment
    By VK1981 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-08-2006, 01:17 AM
  4. Adjusting Wheel Alignment
    By Olden in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2005, 01:08 AM
  5. Wheel alignment
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2004, 02:49 PM
