Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Engine missing V8 308 VK
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Default Engine missing V8 308 VK
    I need some help with this one. Now it's my turn to get some ideas.
    The other day whilst turning into a street, the car coughed a bit like it was missing as I was accellerating up the hill.
    When the car is in park and idling, every 3-4 revs I can hear the motor missing.
    I have checked the spark plugs and the ignition timing is fine. If it was a bad valve then it would be missing every rotation. It's got me stumped.
    I first thought I got a bad tank of gas but that can't be right.
    Any ideas?
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    if its missing at idle as well as accelerating, try your ignition module, its a common problem for them to pack up in the std HEI dizzy...
    No wah to that!
    Never late with ROB308...
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by Slim View Post
    Any ideas?
    have another look at night you may see somthing
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by burnz View Post
    What do you mean? Where?
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    im guessin he's meaning tracking/arching of ignition...
    No wah to that!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by atrail308 View Post
    Don't those usually if failing pack up completely and refuse to start the motor? Thanks.
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    they can sometimes be intermitted, when its on its way out it can show early signs by missing...
    No wah to that!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Cool man. Thanks for suggesting it. I have a mate that has a couple of spare second hand ones that I will try out next week. I think they are $55 each new, so I aren't going to buy one unless I know it's that.
    Any other suggestions before I replace the module?
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    it sounds like its igntion if it does it when you're idling AND accelerating, so just make sure evertything is up to scratch, throw a multimeter on your leads to have a quick check for resistance, also check out your rotor, cap and coil contact points... After all of those, if still being ignition at fault, it could only be your module left...
    good luck man, let us know how you go...
    No wah to that!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Yeah, the leads are Top Guns and are virtually new, only bought 4 months ago and I have only driven about 2000 K's. The rotor was replaced 10 months ago. The coil contacts are fine. I suppose if they wern't, nothing would work.
    I haven't looked at the cap, but if it was cracked, it would probably be doing more than a bit of missing. More like backfiring and running like a total barge.
    Thanks mate.
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    true that is, i'd still say it does sound like your module... give a second hand one a go, then you'll know for sure, but hey, i still may be wrong...
    No wah to that!
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    the lightning
    Jun 2005
    under the Southern Cross
  15. #15
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I'm sure the coil is ok. I am getting this module Friday and he is also lending me his timing gun. I have to take the dizzy out to get the module off. Hopefully I won't run into any other problems.
    Today the car was running like a barge. The engine missing is getting much worse.
  16. #16
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    you can do the module without taking out the dizzy, just undo the 2 screws at the top, then take off the metal cap and unplug the 4 plugs in the module, just make sure you dont get the wires mixed up...
    No wah to that!
  17. #17
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
  18. #18
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    you should be able to, mine's in the same spot... i did it with the dizzy still in so i didnt have to play with the initial timing of the dizzy...
    No wah to that!
  19. #19
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    it makes it a lot easier to have the small cap conversion, a lot more room to move...
    No wah to that!
  20. #20
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    So I should take off the cap extension and then I should be able to get to it without taking it out? If so, great.
    Do the earlier models have a small cap without the extra housing? I thought the purpose of the adaptor and larger cap was to stop cross sparking?
    Cheers.
  21. #21
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yeah, if you take off both parts of your standard dizzy cap, aswell as the rotor button, you'll be able to get to the module without taking out your dizzy...
    as for the small cap conversion, the HEI ford v8's, such as the XE-XF's used the same dizzy but a different rotor button and a small cap, the same as the old red V8's, if your ignition system is up to scratch, there would be no reason for the tracking/arching...
    No wah to that!
  22. #22
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I remember now seeing my mates 253 red motor having the standard cap. Also my cousin's Cleveland XB's & XC's all have the standard small caps. I have only seen the large caps in later model commos.
  23. #23
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    yeah, but just remember the rotor from the old red V8 wont fit cos they were points dizzies, you'll need the rotor from the XE-XF falcoon...
    No wah to that!
  24. #24
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Oh yeah. I know the old reds had a points dizzy, why is it with the electronic ones require the dizzy to be spaced?
  25. #25
    atrail308's Avatar
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    they original had the idea that it would start cross tracking due to the higher output of spark, so they used the larger cap so this problem would not occur... but, if an ignition system is running at the right output, the right timing, a good contact in the right spots and minimal resistance, there is no reason for it to cross track or arch out...
    No wah to that!
  1. Engine missing at revs
    By NVS 90 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2007, 04:29 PM
  2. missing engine bolt?
    By commisme in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-11-2006, 06:48 PM
  3. Missing down low
    By Joes_meat in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-06-2006, 05:10 PM
  4. engine missing
    By seabass in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:07 PM
