Results 1 to 12 of 12
Thread: power loss through lpg
    vk commodore
    Apr 2006
    Default power loss through lpg
    gday
    i was just wondering if anyone knows roughly how much power will be lost when using lpg on a carby engine. i know there is a fair amount of loss on an efi, but seems to be little, if any, on a carby car
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I lose about 20 KW or 20-30% less power on my 5L V8. This is an estimate I have observed. Same would probably be for 6 cyl models.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    VR Statesman V8
    Jun 2006
    Ya will get power loss on a carby car with LPG, mine does. Probably a 20% drop, just depends on whether you want the economy of LPG or the power of Petrol. You can change over to petrol on the run, just pump the accelerator a few times and away ya go. Going from Petrol back to gas you need to run all the petrol out of the carby first before flicking on the gas or it'll run REAL RICH and run like a PIG. Ya get used to it, I usually run mine on gas till it runs out, flick to petrol and drive to the next cheap servo. That way it gets a little run on petrol and keep the carby seals wet.
    '94 VR Statesman V8
    Petrol/LPGas and Pod filter, Pacemaker Headers, 16x7 BSA 248 wheels
    '90 EA Falcon Wagon 3.9MPFI Petrol/Gas, Work car
    1923 T-Bucket (Hot-Rod) 6/71 Supercharged LT1 350 Chev, T350, Jag rear
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    94 Stato V8, I don't think the OP was asking for instructions on how to run a dual fuel car. Whilst you are correct though about from switching from petrol to gas. It's basically flooding your combustion chamber of fuel. There is still quite amount of fuel left in the carb if you switched it straight over, so you need to run the carb dry of petrol (i.e until it chugs) before you switch it over.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by 94 Stato V8 View Post
    No offense, but do you know what you mean by saying "carby seals wet"?
    Reminds me of my brother. Some dikhead said that if he switched over to petrol after running on lpg (only) for 5 years his whole engine bay would ignite and blow up. Like really. Think about it. The only thing between the petrol tank and the carb is about two short rubber hoses and a steel rod. So what if your carb gaskets have gone a bit dry. They do after wear and tear anyway.
    If someone could prove to me that a car engine bay would blow up when switched to petrol with a car running lpg for a few years, I will give them a $100 right now.
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    Quote Originally Posted by Slim View Post
    LOL, do i get the $100 just for blowing the car up under any circumstances :P
    BTW, power loss on a carbied engine isnt that bad, i found it practically unnoticeable untill u found a hill. Things that would help would be the timing, as the two different fuels require different timing settings to run at their peak.
    ie, the timing on my ol VC, the petrol was advanced a fair bit just so that the lpg would run at its best.
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Quote Originally Posted by vkhawkey View Post
    gday
    A car with a carby engine will lose a lot more power on LPG, than a car with an efi engine.....
    I like my roo well done
    VR Statesman V8
    Jun 2006
    Default Hey Slim
    None taken
    Ok you got me on a technicality, I actually meant "carby GASKETS wet"
    I dont know if you have had a problem with a carby with dry gaskets before or not, but I have, and they leak petrol everywhere, hence the reason to run on petrol occasionly to keep them wet so they dont go thin when they dry out.
    Sorry I cant take your $100 either as I know they wont blow up, just might catch fire if the fuel leaks on some hot pipes.
    '94 VR Statesman V8
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    It is true that the gasket gets a little brittle. The gaskets can get rooted after a while even with running petrol regulary. The gaskets in the carb would need to be quite cactus for fuel to be leaking out of it. It would be pretty rare IMO for the fuel to leak out and ignite but not impossible. But as for blowing up, that turkey who described it to my bro was going a bit over the top.
    vz wagon
    Aug 2006
    Wild west of Melb
    The main thing that will die if not ran on fuel once in a wile is ya fuel pump.
    And a carby car will lose more power than a efi car that is if the gas is installed the right way .
    vk commodore
    Apr 2006
    so wat would a lumpy cam be like when running lpg. im told they are no good and a stock cam will perform better wen run on lpg
  1. Loss of power...
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2005, 01:01 PM
  2. Loss of power
    By BLUE_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 11:23 PM
  3. what causes power loss
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 10:20 PM
  4. loss of power
    By rail in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2005, 04:54 PM
  5. Power Loss
    By TheLucksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2004, 09:11 PM
