Results 1 to 20 of 20
Thread: Known Berlina and Calais problems
    matty88's Avatar
    matty88 is offline LPG Installer :p
    TEXXXY: Resprayed TX3 Non Turbo
    Aug 2005
    Doveton
    Default Known Berlina and Calais problems
    Gday
    Just wondering as I'm looking to buy a VK Calais or Berlina, what known issues/problems have risen that I should check for?
    308 VK Calais, VK EFI Berlina, V6 VN & Kenworth...
    Nov 2005
    Adelaide(City of Godbothers)Churches S.A.
    The only thing I know of with the Calais are the Electronic/Star Wars dash.They are crap, innacurate & most likely faulty.I must have a 'fluke' 1 or maybe it's just waiting to sh.t itself.Being all Electronic + 22 yrs old says it all.Speedo Transducers are another but only the Calais have them.
    Tony 308vkcalais:
    VK Calais
    Feb 2006
    Or maybe there not as shit as people lead you to beleive? Mines the original, and I'm told there as accurate as hell, how does a speedo transducer as basic as the VK Calais ever shift out of calibration? Only thing mine does is flutter when under 15km lol.
    matty88's Avatar
    Aug 2005
    Doveton
    Nov 2005
    Nothing's wrong with my dash, I've read alot of post on here about them.I personally think they're crap, gimmicky & not as functional as the Berlina.It shows more eng info.
    Tony 308vkcalais:
    the lightning
    Jun 2005
    under the Southern Cross
    other problems;
    the electric windows / power mirrors can be touchy or not work at all or be very tight and sound very strained when operating.
    the setup in the rear doors is a bitch to work on or replace I've been told and have seen for myself that it doesnt look overly simple.
    being a 22 year old car its gonna have all the usual problems of a car that age i guess
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    I have seen various people here saying the electro dashes are good and bad. Seems about 1/2 the people think they are ok and the other 1/2 think they are shit.
    Anyway, I have had various speedo checks on the highway and I swear my digital speedo is 110% accurate. I was going 107 on one of the highways and it was dead spot on.
    I don't think there was ever an option in the Calais to have an SL dash. I suppose if you wanted it, the price on the new car would still be the same.
    I would advise the OP and anyone else, to see this site for your fault info:
    http://au.geocities.com/commodoretech/vkfaults.html
    Book mark it as your VB-VK problems info site.
    Nov 2005
    Yer, anything 22 yrs old isn't gunna work properly in reality.I've had the whole dash out a few times & the amount of fine dust that collects up around the dash area it's no wonder they're dodgy.Settling on Electronic connections it wat happens.
    Tony 308vkcalais:
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by matty88 View Post
    Gday
    I should expand a bit more than just the dash.
    Underbody worn out bushes.
    Rooted front or rear springs/struts.
    Tired motor, rooted valve stem seals or worn out valves. A compression test on all cylinders can give an indication of the condition of the motor.
    Bad transmission. Inproper gear change.
    There would be more. It's a fairly older vehicle, typical but unless it's been looked after, there would be a lot of work needing done unless it was fully rebuilt.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Apart from GMH, has anyone ever figured out how to transfer speedo readings or simply reset the odo on the dig dash?
    Nov 2005
    Quote Originally Posted by Slim View Post
    Slim...u just described my Calais when I 1st got it.Leaked every fluid it carried, no drive....
    Tony 308vkcalais:
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    God invented gaskets.
    When I got my Calais, I spent $250 on bushings + about 4 hours of work because they were cactus. Now I believe my underbody is about as good as it was back in September 1984.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Suspect bushings on the VK for its age are:
    Radius rods.
    Lower control arms (front near the ball joints)
    Rear lower trailing arms front and rear.
    Rear upper trailing arms front and rear (Mine were fine though)
    Front and rear stabiliser bar links. 8 front, 8 back. (Mostly for body roll stabilising. Rubbers can squish a bit after time.)
    Only replace with Nolathane or urethane rubber bushings if you're smart.
    Many bushes require the use of a hydraulic press to push out and in the bushings. You can make your own bush removal and install tools out of all threads and steel cups and large washers.
    My advise is don't buy a VK with worn bushes unless you know someone who can replace them for nothing. A mechanic would charge a million bucks in labour.
    Nov 2005
    Here's her front end on her 202 Berlina I rebuilt.
    Attached Thumbnails Attached Thumbnails Known Berlina and Calais problems-berlina-steering-rack-parts.jpg   Known Berlina and Calais problems-berlina-front-r.jpg   Known Berlina and Calais problems-berlina-front-l.jpg   Known Berlina and Calais problems-berlina-top-strut-l.jpg
    Tony 308vkcalais:
  15. #15
    VN/VT
    Sep 2005
    SA
    Quote Originally Posted by 308vkcalais View Post
    if ya don't mind me asking, how much did it set you back 2 do that?
  16. #16
    matty88's Avatar
    Aug 2005
    Doveton
    Cheers guys, if I buy one I'll be restoring it as money comes to hand. I plan to rip out the engine and do a full rebuild, to save problems later (plus I love messing around with engines). There's a berlina for sale down the road from me that I've got my eye on, no price listed but when they park it out on the lawn again I'll ask...
  17. #17
    Nov 2005
    Default FrontEndRepair Costs
    Quote Originally Posted by sirVkcalais View Post
    All up it was around $400 in parts, that including the new GT Gas inserts.Dunno how much a mechanic would've charged.I can whip out both struts in 30 mins & rebuild the entire front in around 4hrs.New Rack included.I've dun it sooo many, many times
    Tony 308vkcalais:
  18. #18
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    What did the stabiliser bar cost you and why did you not just use the original one?
  19. #19
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I was thinking about taking my front and rear bars off and spraying them silver.
  20. #20
    Nov 2005
    Default Stab Bar
    It's the original 24mm job, I just sweetened it up wif a lick of gloss engine yellow
    Tony 308vkcalais:
  1. Vr Berlina Ecu Problems (help!)
    By mrlambrou in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-04-2007, 12:04 PM
  2. VT Berlina Problems
    By hazavt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2006, 08:08 AM
  3. VT Berlina Problems
    By hazavt in forum General
    Last Post: 27-11-2006, 04:08 PM
  4. Replies: 57
    Last Post: 12-10-2006, 08:47 AM
  5. Vr Berlina Problems Please Help
    By Gold_VR_Berlina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2004, 06:41 PM
