Results 1 to 9 of 9
Thread: God dammit!! Dizzy gear :(
    synoptica's Avatar
    synoptica is offline Stripping VK - PM me!
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    Default God dammit!! Dizzy gear :(
    Hey guys,
    Just managed to accidentially knock the cap off the dizzy while trying to adjust the timing... ended up ****ing the gear... but instead of finding a gear missing a couple of teeth like I expected... I find... NO GEAR!
    So... do we think this could be a bad thing, having that floating about inside the engine and all? I'm thinking so... but I know there's a few teeth floating about from the last time I did this... so maybe not?
    Thoughts?
    - Chris.
    91 FORD EA Falcon (So sue me)
    Sep 2005
    Opononi, NZ
    well, my VC did that, stripped the gears on the drive gear. didnt have any problems. just replaced the entire gear with a steel one. As for the whole gear itself... not sure, but i couldnt imagine it would be very healthy for the engine.
    VS Exec, VC SL/E V8, 2x Lada Nivas
    May 2005
    it will be in your sump the oil pick up wont pick it up so you should be ok
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    As ENVS said. You'd need to take your sump off to get it out. Personally I wouldn't want it floating around but it shouldn't do any damage because the oil suction won't pick it up. You should be able to get a new gear as a spare part.
    the lightning
    Jun 2005
    under the Southern Cross
    get a bronze dizzy gear (cam manufacturers advise against them but I've run em for years in a hot 202 without any dramas) as the nylon ones always strip teeth, you can fish the old one out of the sump by removing the timing cover and try fishing it out from the front using some wire or something, otherwise it wil sit fairly harmlessly in the bottom of the sump. Personally I'd leave it.
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    I've got an engine that'll be complete in the next few weeks ready to go in before the end of the year - solong as it's not doing any damage sitting down there and posing no significant rist it can stay the hell there.
    As for the nylon v steel - last time the ignition mob advised the same. This time I'm gonna tell them what I want and to put it on regardless
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    Why you would use a nylon gear is beyond me. OOops. I hope my gear is steel in my barge. I am sure it would be.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Hi Guys,
    If you want a cheap replacement gear for your dizzy, get an old 202 oil pump and remove the gear from that and fit it to your dizzy. It will never strip, never wear out.
    The reason they originally run a nylon gear is as a safe guard against camshaft damage if the dizzy shaft locks for any reason. I have never had it happen.
    cheers
    Scott
    synoptica's Avatar
    VT povpack wagon!
    Nov 2004
    Hawthorn East, Vic
    The dizzy shop refused to put a metal one on
    But for a $15 fix, I really can't complain eh?
  1. stripped dizzy gear
    By VRSS in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-04-2007, 01:19 PM
  2. Dammit!!!
    By Famine in forum The Pub
    Last Post: 17-10-2006, 09:49 PM
  3. DAMMIT! radiator
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-06-2006, 09:14 PM
  4. Dammit!
    By mike_is_bored316 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-08-2005, 05:20 PM
  5. Dammit
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2005, 01:39 PM
