Results 1 to 6 of 6
Thread: diff
    vk commodore
    Apr 2006
    Default diff
    ive just purchased a 308 4 speed vk to wreck. ive removed the rear axle and found out that the diff ratio is 2.60:1. is this normal for a manual car or should it be different? also, is there a way i can tell from the housing that if the diff is a 10 bolt or not, and whether or not its an lsd?
    cheers
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    OK usually the manual VKs used a 3.08:1 ratio, the 2.60:1 would be a pig to drive.
    To tell if the diff is a 10 bolt, have a look at the cover plate, if its egg shape, 10 bolt. If round, 8 bolt. To tell if its a LSD, should have a tag on the filler bolt. If not there, have the rear of the car in the air, use jack stands, and spin one side of the wheel and see if the other side is travelling the same way, LSD, if not single spinner
    vk commodore
    Apr 2006
    cheers, i'l have a look tomorrow. still not sure what you mean about checking if its an lsd or not though
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Well hmmm spin the drivers side wheel clock wise and the passenger side will move in the same direction, this will be a LSD Diff. If the drivers side spins clock wise and the passenger side spins the opposite direction, single spinner diff.
    VE SII Sv6 Manual
    Aug 2004
    Easy test is jack up the rear and put it on stands. leave hand brake off and put it in gear for manual or park for auto, try and turn one of the wheels. if they turn easily then it's a single spinner, if they turn with a lot of effort it could be a worn lsd or the motor is turning over with you effort, if they don't turn then it's deffinitely an lsd or locker.
    vk commodore
    Apr 2006
    ive looked at the diff, it has an oval housing so im guessing that its a 10 bolt. i did the test SL/ENUT recommended and can assume it is not an lsd. rear axle is now in car. just the engine n gearbox to go. i'll reply back to this thread to report on wat i think about the 2.60:1 diff ratio in a manual. thanks for all the assistance
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  4. VL Diff
    By Hooligan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-05-2007, 09:04 PM
  5. EL XR6 diff on VS?
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 05:39 PM
