Results 1 to 2 of 2
Thread: Last timing questions.
    Goon's Avatar
    Goon is offline The Future.
    04VYS2/V6. 79VBSL6. 04Mazda3
    Feb 2006
    GC. QLD
    Default Last timing questions.
    Hey All
    I just need to as ka few question to get the faq's straight.
    1# Okay with the engine timing at 6'd, would this every get effected by touching the carby settings? and dizzy postion?
    2# timing moves at 2 degress at a time? so 3 turns would equal 6!
    3# Air/Mixture screw Clockwise lowers revs? Anti clockwise increase rpm ? **could be back to front**
    4# level of fuel in filter, will show if shes running to rich or to lean? this would mean the screw can control how much fuel the pump is pumping?
    5# Should the dizzy vaccum hose before off while turning the air/mix screw if you where tuning with the dizzy at the sametime? as the dizzy also controls rpm.
    6# whats a flat spot
    Quote Originally Posted by Jamie-b View Post
    well i think a "headjob" would be better than stroking it?
    Goon's Avatar
    Feb 2006
    GC. QLD
    dont worry thanks.
    I got these answerd.
  1. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 05-10-2007, 12:04 AM
  2. vs v8 timing help!
    By mean in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 03:52 PM
  3. VL Cam Timing
    By vetteman in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-06-2006, 07:48 PM
  4. How to set VK Timing
    By vaughan in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-01-2006, 08:37 PM
  5. 308 timing
    By vkgirl in forum Electrical Wiring / Questions
    Last Post: 14-10-2005, 09:53 PM
