Results 1 to 6 of 6
Thread: interchangable diffs
    355vh is offline READY WHEN U ARE
    VT SS SI 5LT M5
    Oct 2006
    MELBOURNE
    Default interchangable diffs
    will a entire diff assembely from a vk commodore sedan bolt staight into a vh slx wagon
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    nope.
    Wagon has a slightly wider wheel track, suspension mountings are different.
    cheers
    Scott
    VT SS SI 5LT M5
    Oct 2006
    MELBOURNE
    VT SS SI 5LT M5
    Oct 2006
    MELBOURNE
    Default diifs
    is there any way to fit the sedan diff in the wagon any alterrations i can do?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    yeah I suppose you could modify the diff but not much point the cost/time to do it would be huge.
    If you diff is buggered the internals out of a sedan diff will bolt into a wagon, except axels of course.
    really your better off finding a wagon diff.
    Apr 2005
    I only just completed a swap from a 6 cylinder wagon diff to a V8 salisbury disc sedan rear 2 days ago. All I did to make it fit was grind the sedan shocker mounts off, clean the excess welds to neaten it up and after using the angle grinder with a cutting wheel, removed the wagon shock absorber brackets, then transferred them over, all from the cost of a cutting wheel. You could do it alot easier with a little cutting wheel on a die grinder tho'., easy. Everything else bolts straight up...
  1. Are all V6 ecotec manual gearboxs the same and interchangable
    By blowme in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2007, 07:02 PM
  2. Diffs
    By holden08 in forum V8 Development and Modification
    Last Post: 20-03-2007, 11:44 AM
  3. vs diffs
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 06:45 PM
  4. what wheels are interchangable
    By artrix in forum General
    Last Post: 12-08-2006, 08:06 PM
  5. Interchangable parts on VN motors?
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2006, 11:23 AM
